Greetings All!
My name is Russ, of R&R Modelers, again. If you have not seen any of our posts before, we are not a business, just a friendship and collaboration between two modelers, Ron and I, to make models. We have posted some of our projects (at various phases of completion) on this forum and they may be seen at:
http://cs.finescale.com/fsm/modeling_subjects/f/48/t/158982.aspx
http://cs.finescale.com/fsm/modeling_subjects/f/48/t/159017.aspx
http://cs.finescale.com/fsm/modeling_subjects/f/48/t/159041.aspx
http://cs.finescale.com/fsm/modeling_subjects/f/48/t/160518.aspx
http://cs.finescale.com/fsm/modeling_subjects/f/48/p/162598/1772871.aspx#1772871
This thread shows the 1/144 Scale Cessna 421C Golden Eagle, a light twin-engine personal transport aircraft with a pressurized cabin, first produced in May 1967. The 421A appeared in 1968 and the aircraft was redesigned in 1970 as the 421B. The 421C followed in 1975, and featured wet wings, the absence of wingtip fuel tanks and landing gear that were changed from straight-leg to a trailing-link design from the 1981 model year onwards. Production ended in 1985 after 1,901 aircraft had been delivered.
The model was designed using AutoCad, along with plans and pictures found on-line, including the picture shown below.
Once again I started by importing the plans I found into AutoCad, scaling them to size, tracing the sections, moving and rotating them into position, then using the Loft and Extrude commands to make the airframe. In the image below I have also added the tail.
The image below shows development of the engine nacelles using the sections from the plans and the wings, I created using my own sections.
The image below shows the model after I had joined the various components.
The next thing I did was dice and slice the model to create various features, including the cabin, cabin doors, cabin windows, ailerons, rudder and elevators.
The next image shows the top separated to reveal the airframe I had hollowed out.
Next, I copied a propeller that I had previously made for the 1/350 scale AC-47, scaled it up, and created the nose cone for it. You can see that I had also started the process of making the landing gear.
The next group of images show the gear. In the top two images, the main gear have not been completed.
…And here they are from underneath…
…And from the front left.
Stay Tuned…
