The mystery of scale
What material is that? I can see that you have to insert the pins to complete a link (looks like two bits to make a full link there), however I cannot see how the links interconnect. Is that another set of pins?
That is “mad” detail level, though I suspect it makes a very realistic tread, sag and all. 3D Printing is a real game changer for models. Right now, I am just not interested in having a Resin SLA Printer, not having even opened my Creality Ender 3 unit my daughter’s beau purchased for me about this time two years ago.
I’m still trying to figure out how to clear a space to set the printer up in the house where I can control the temp and humidity independent of the rest of the house. With an SLA unit, the cost is higher, the resins more of a potential chemical fume issue and any spills and leftovers are a potential problem in the house with wall to wall carpeting everywhere other than bathrooms and kitchen.
Those treads, though… that sort of detail is making me scratch my chin and wonder.
I think it’s 3-D printed resin,yes they are very nice,they simply join together and are held by one pin on each side,surprisingly I have over 65 of the 89 links for one side done,and no broken pins,they slide in easy and stay put.
I’m just going to chime in here that 1/48 scale and 1/4 scale are not the same, although “quarter scale” is sometime used as shorthand for 1/48 scale. The shorthand may work in a limited capacity for American measurements, but it’s not accurate.
In 1/48 scale 1 inch = 48 scale inches = 4 feet.
In 1/4 scale 1 inch = 4 scale inches =/= 4 feet.
In 1/48 scale 1cm = 48 scale cm.
In 1/4 scale 1cm = 4 scale cm.
1/48 scale is 48 times smaller than the real thing.
1/4 scale is 4 times smaller than the real thing, or one quarter the size; one quarter scale.
A 1/4 scale bust is a pretty big model. A 1/48 scale bust is a tiny head missing the rest of the figure.
Ok that explains a lot. I thought I was losing my mind. I had no idea there were two 1/48 scale readings. Thanks Tim.
1/4" scale is actually in engineering terms 1/4" = a foot… and yes equals 1/48th actual scale…
And has been for hundreds of years… (naval yard/constructors models are historically built in 1/48th scale and have been since the early 1500’s)
Quarter scale, one inch equals one quarter inch, is a very large scale…Very little modeling is done in one quarter scale…
Quarter scale is big in the R/C world
It’s used in figs, too. Too often the “inch” is left off on the shorthand, and even then it still causes confusion. We’ve had to explain it many times over the years at FSM.
In fact, this thread has given me an idea for the From the Editor page.
There is confusion on scaling… Has been for centuries…
Pure mechanical scale, vs. Architectural scale, vs Naval Constructors scale… (then there’s model railroad scale, RC aircraft scale, RC tank scale etc etc) There as are many different scales as there are model builders…
Scale is a ratio of the length of the model compared to the real or full size object expressed as scale length compared to real length… (ie 1/350th, 1/35th, 1/48th, etc, etc) There are common scales that have been around for centuries. Engineers, Architects and Naval Constructors have developed specific rulers as common tools for their trade to make drawing and building in scale easier…
Naval constructors were probably the first and about the same time builders used scale to represent buildings, Engineers used it as machine tools started getting larger and larger…
So as modelers, we pick a scale we want model in and build accordingly, there is no right or wrong…
There are hundreds of modeling scales out there…
like I said, there is no right or wrong to scale…
Even with this new information, and the fact I agree with all of you on the interpretations of scale and how it works, here is my…“straight poop” on scale.
If you tell me that 1 inch equals 48 inches, then I interpret that, regardless of the genre it comes from, to mean that every 1 inch long that I build something, it equals 4 feet in real life measurement. So the model train track cleaning cars I made 10 inches long equal a 40 foot long flat car on a real train. Not many of those in existence, I think 60 feet is the norm. So if I wanted to build an accurate model of a model train 60 foot long flat car, I would have to build a 15 inch long car. But, accurate doesn’t always translate to functional. Granted my layout has long curves to accommodate this not so useable length, but not all O scale layouts will. Most model train enthusiasts do not have a 20x20 former water cistern under their garage that could be converted to a train room. So, Lionel, took some liberties with O scale and made smaller, what MTH model trains call “Railking” class rolling stock and Locomotives. MTH also has their premier class, now built by Atlas, I guess, who knows with that company, one day they are going out of business light, then when you think they are a skeleton company, you find out they are as at work as they were before Mike Wolfe decided to sell out and go fishing. Anyway, Premiere is “true” 1/48 measurement. If the real Locomotive is 96 feet long, then the model is 24 inches long. I think mine are 18 and change inches so my guess is the real thing is 73 feet.
My point, as I ramble, as usual, to keep you guessing, a lot of Paul Harvey in me, this is how I interpret scale. Even though the companies may massage it for whatever good reason they had, it is what it is. If you say “the code book says, Red = Stop”, then whenever I see red, I’m stopping. That it’s monday, doesn’t impress me much. That today you are wearing jeans instead of slacks means nothing to me. You said, and I quote, Red means Stop. I don’t remember any implied crap about it being on odd weekdays or when you wear jeans.
Once I was told that full length means from the tip of the rotor to the tip of the stinger tail piece, I measured my 1/48 huey model again and guess what, it was 57 feet 1 inch long. How long is a real Huey? 57 feet 1 inch. 1 inch=4 feet. That it was an Army Huey, did not matter. That it was a Navy Huey, did not matter. That is was a model railroad Huey, did not matter. 1 inch = 4 feet. 48 inches, a whole lot more half inches, a ton of 16ths. I’m not denying the individual differences listed, I’m simply saying that 1+1 is always 2 in pretty much every country that uses numbers. Mexico may call the number 1 uno, but uno + uno always equals dos. Scale seems to hinge on interpretation. There’s a Navy version of 1 inch equals 4 feet? In the Navy if you are given 1 hour to get up, shower and be in formation, and I show up 59 minutes later in formation at attention, I’m somehow late because an hour in Navy time is actually 58 minutes?
Just trying to see if you see how dumb that sounds
Chopper, some folks don’t describe the same things the same way. This has always been the case.
That said, when it comes to scale as laid out in a ratio or a fraction, this is ALWAYS true: The first number is the actual scale to the second number. It doesn’t matter if it’s inches, feet, centimeters or millimeters, as long as BOTH numbers are using the same measurement the scale is stable.
Therefore: 1:48, 1:8, 1:32, 1/4, 1/24 or 1/86 (see what I did there?) it doesn’t matter. That ratio or fraction always says "One of this measurement (be that inches, feet, millimeters or meters) for this item (be it a model kit, an architect’s desing or a shipbuilder’s blueprint) here is equal to this many of those same measurements in real life.
So if you want to measure feet, inches, millimeters, centimeters, yards or meters, as long as the first number in the ‘equation’ is your baseline, then the rest of the math checks out.
Unless someone laid out the dimensions incorrectly in the item being set to scale.
Now, if you were to, say, buid a model of an ant, you’d need to scale it slightly differently. In such a case where the model is going to be larger than in real life the ratio or fraction is reversed.
Like this: 4:1, 8/1 or 24:1. In those instances the ratio tells you that this scale is magnified such that, for the 4:1 scale it’s telling you 'every unit of measurement (the 1 side of the equation) is going to be this many times larger than it actually is. Say you want to make a scale model of that ant. It might be set to be four inches long when finished, but the real ant is only 1/4" long.
Mathematically, one would ‘properly’ convert those 4" of model length into a fraction in X/4" scale, such that you could determine how much ‘magnification’ that ant gets to be 4" long. For the sake of completeness: 4" = 16 1/4" ticks on a scale, such that the 4:1 ratio is 16/4, knowing, in this particular case that the 1/4" real life item has been magnified 16 times.
I have’t even had my morning cocoa yet and I can still do math. Wonder of wonders.
All those other references to Navy, Shipbuilding, Architectural were just a sort of history lesson for the folks who used scale references to the point where they have specialized rulers for the purpose of scaling things to set standards. The math still works and the reasoning is still the same:
You’re either making something smaller than it really is by a set ratio or making it larger than it really is by a set ratio. The base measurement (1) is always the same measurement for the item being depicted.
If it’s on the ‘top’ of the fraction or the first number in a ratio, the item is smaller than real life, if it’s at the ‘bottom’ of the fraction or the second number in the ratio, the item is larger than it is in real life.
See what you’ve done? You’ve got me going again.
Well, if I have you going, I’ll interpret that as I’ve peaked your boiling point. That warrants you knowing my first name. John. We are beyond Chop Chief. My apologies for raising your blood pressure. I’m also, sidebar here, interested in what you mean by the first number. It’s a 1. Bear with me here, but I’ve never seen any scale ratio begin with anything else. 1/?. Thanks to this site I now know that the second number always means the corresponding measurement. Whether it’s 48, 32, 35 or 200. I now know that smaller is larger. I also know that 35 gets small enough in parts that I don’t dare go higher than 48. I can only imagine how small the parts are on 200. I’m putting together a jeep that’s 1/35 by Tamyia. Great model, but there are two parts that I had to hope even with magnifying glasses that I hit the mark. But, it’s a Jeep. A 1/35 B52 is going to be a larger model than a 1/35 bicycle. That’s why if I wanted to put together a Harley-Davidson, 1/24 or 1/18 scale would be much easier on the eyes and hands than a 1/35 or 1/48 motorcycle.
As for the actual subject matter of this thread, all we really need to know as far as scale goes, is just what I alluded too. The larger /number, the smaller the size of the model and yes, that tinier the parts you’ll have to deal with. So if you have Paul Bunion hands and wear coke bottle bottoms for glasses, maybe you might want to stick to 32 or smaller in scale. However, if you have robot hands with feather touch and hubble telescope eyes, go as large as you want on the /number. But as for the first number, I’ve never seen anything but 1. Now when you get into ratios and converting those, that’s a whole new ballgame. But hey, at least now I know what 4 to 1 means. Thanks.
John
Hey, John, no increase in blood pressure. I enjoy having my mind’s gears turning.
The first number (as in my ant model example) is not always 1. 1 is always PART of the expression (whether it’s a fraction or ratio). If the 1 is first, the item is smaller than actual size. IF the 1 is in the second part of the expression, then the model is larger than actual size.
You won’t see very many models expressed with 1 as the second portion of the expression, however if you get to scientific models of things like insects, arachnids and other ‘bugs’ (those that are neither insects nor arachnids, like a millipede for example) then you’ll see the 1 posted in the second part of the ratio or fraction.
Hope that clears that little bit up for you.
Glad to hear. I’m not fond of my posts getting all facebook or twitter over something as benign as model scales. This whole thing began because I didn’t know how to measure the full length of a helicopter and was certain my Italyeri mode wasn’t 1/48 scale. Once I learned how to measure it, it was dead on accurate.
As for the 1/?. I’m simply talking about what’s on the box. Granted ratios can be 3 to 1, 5 to 4, the list goes on. But as far as company scale in reference to the scale of the plastic model or train model, 1/whatever has always just mean 1 inch=?. I guess another explanation to help with this is that I see these “magnificent” train layouts on YouTube, well used to until I got back into Bass fishing, then it was endless “use this lure when…” or “why bass don’t bite when they’re dead”. Now it’s all scale models and the many things to learn from those. But I’d see these train layouts that had tonka toys as cars on the street. The car was bigger than the Locomotive. Lumber yards with what would be, in scale, fully grown redwood trees passing off as scale lumber. Babies sitting in the front yard on a towel with mom and the baby is the size of Shaq. And these were supposed to be detail oriented layouts.
Chopper_Chief, I have to admit I’m a little confused about what we’re actually disagreeing on here. :grin:
You started by saying you agree with us, and then made several points that seem to reinforce exactly what we’ve been saying.
To me, 1/48 scale is 1/48 scale. One inch represents 48 inches, regardless of what we’re modeling. Whether a manufacturer accurately reproduces something at that scale is an entirely different question. Manufacturers make compromises, take shortcuts, and sometimes just get things wrong. None of that changes the definition of scale.
As for the train example, I don’t know why a manufacturer would choose to represent a 60-foot railcar as a 40-foot one, but that’s a design decision on their part. It doesn’t mean the definition of scale has changed. It just means they’ve chosen not to reproduce the original dimensions accurately.
So I’m genuinely curious. What part of the scale discussion do you feel we’re still disagreeing about? Because from where I’m sitting, it sounds like we’re all saying pretty much the same thing!
“To me, 1/48 scale is 1/48 scale. One inch represents 48 inches, regardless of what we’re modeling. Whether a manufacturer accurately reproduces something at that scale is an entirely different question. Manufacturers make compromises, take shortcuts, and sometimes just get things wrong. None of that changes the definition of scale”
Exactly. You and I agree fully on that aspect of scale. You said it, why some company’s feel it necessary to skimp on size when actual size is fine, we will never know. In railroads it’s due to the fact some enthusiasts want larger size trains, but they don’t have the room to build a layout that fully expresses their love of the hobby. I want O scale but all I have is a table in a cluttered basement. O gauge has the operating components they like. Lionel saw this and made sort of an O scale light version. You can tell when you take a lionel box car for instance and set it next to an MTH premiere version (actual 1/48 scale). The lionel box car is obviously smaller, but yet it is and “O” scale or 1/48 scale car. Thanks to that the train can navigate the sharper curves needed for the small confined track layout the example I spoke of is forced to use that actual O scale designed locomotives and rolling stock cannot.
As for scale models, this problem is not an issue. But where I was getting “really? Why does this have to be hard?” attitude about this was all the talk about how 1/48th scale means different things to different people. But as you say, and I fully agree, 1 inch =4 feet. Enough said. If NASA, the Navy, Project Engineers, Santa Claus, the Easter Bunny, and John Paul Jones want to have their own definition of the same word that means one thing, fine with me. But when I find what appear to be conflicts in size of parts based on the fact this was supposed to be a 1/32 scale C130, and a box the size of a small picture frame shows up with a C130 that you can barely see the wings, I get confused. I just built a UH-1 1/32 scale and the smallest part was a flight control unit. The rest of the parts were large enough for me to see them without wearing magnifiyer glasses. I’m just making up an example by the way. So I search the air waves for 1/32 scale models because they have big parts I can see and hold, and I get a C130 even a bald eagle couldn’t see without glasses. I finally say, “what the hell is going on here”. So I ask my friends on the forum, “what’s up with scale in this hobby?”
Now I’m fully versed in how 1/48, which at one time in my life was simply 1 inch = 4 feet, is now “so much more than that”. It depends on the weather, the shape of the moon, how well the cowboys did in the their third game of the season, what color shirt I’m wearing. Now I don’t know what to believe. At least until you wrote back asking what’s my problem? 1 inch equals 4 feet, enough said. Damn right brother.
Thanks for following up. I’m glad we’re on the same page. I understand the frustration. Some people just want a fun build and don’t worry about small deviations, while others really notice them and care a lot. Sounds like you’re in that second group, and that’s completely fair. Thanks for clarifying what
Happy to do so. I admit I can be and am a bit of a pill when it comes to certain topics. My grandson brought that side of me out. I also admit that when it comes to model building, it will always be a sidebar topic. Just too expensive what with most of the models being made overseas. Nothing against that, but I had no idea Revell was a german company. I had no idea Monogram was one of the few located in the U.S., and just found out that even Tamyia as great as their models are, they mistakes to. Love how they make the parts to fit, but toward the end, found some mold miscues that made finishing a bit tough. But I learned once again that certain parts go on first, then you put those other parts on. In other words, model building is causing me to learn to pay attention to what I am doing, by presenting obstacles I didn’t know were there…until they became obstacles. Don’t put the jerry can and the spare tire on UNTIL you have installed the rear railing. It’s easier to install the side rails if you install the rear rail first. Also, don’t buy inexpensive versions of models you are accustomed to seeing sold for $50 to $80. If $15 plus shipping seems like a steal, person doesn’t know what they have, well, there are two ways to interpret that. They truly have no idea how popular that model is and the desire for it, and, they basically have the parts haphazard in a box and don’t know what they have. I found an inexpensive version of my favorite UH-1D Gunship, and discovered during inspection, one seat was not there, both nose supports were not there, and one side of the engine was not there. I also noticed the box appeared humidity warped and none of the parts were in any bags. The mystery of scale just became the mystery of the Ebay buy
