My bone to pick with scale is more about size than measurement, but I feel you on this one Christopher. Working with model trains was my first introduction to scale and it has its own “why not just”. O scale, O gauge, HO scale, N, S, G, and the famous but seldom used T.
O gauge I have discovered is more about track width than locomotive size. O scale is 1/48. HO is supposedly “half O” which if I am correct, math being what it is today, would be 1/24, but I know now that’s not right because if it was, HO would be a larger version of a train, not a smaller. If we stick to what I have learned, HO would be at the least, 1/64 scale. If 1/48 means 1 inch on a real scale equals 48 inches or 4 feet on a toy scale, then by virtue of what I know from scale models, HO would have to be a larger number than 48, not smaller.
My point is that scale seems to fluctuate depending on the hobby. But in regards to size, 1/32 which is what my favorite UH-1D happens to be, is soooooooo much easier to build. Not only that, the parts are thicker, sturdier, until you reach the top of the rotor mast then they get stupid thin and weak, but the engine, transmission, rotor blades, Skids, all made of thick, bendable, formable, plastic that you can actually see without magnification glasses. Move up 3 notches to 1/35 and now we get the same helicopter, for example, with a tail rotor that might be the size of a tire on a Jeep. Today’s models, though magnificent where detail is concerned, are made of thin, easily broken if you don’t take care to handle them with care. I am assembling a 1/35 Tamyia Jeep right now. It has been a joy to put together. All the parts fit correctly, easy to put in place, but when you get to the front windshield, the windows are made of razor thin clear plastic and they didn’t quite get those cut right. There are two, and when I say microscopic pieces I am being generous, that go on each side of the window frame that I can barely see much less pick up with my hands. Thank goodness for Blu tack. Parts that even in a new born babies tiny little hands would disappear. In some cases, I think the companies go overboard with the attached pieces. Sometimes it is easier and more efficient, due to size, I come back around, to just mold the part into the part. Can you imagine what it would be like on a 1/48 scale model if they forced you to glue the trigger on a rifle to the rifle? This is almost that. Get picky with the bigger models, mold the door handles to the door on the smaller sizes. Or have advanced clock maker type models for the sadists who want to glue each rivet on the plane.
