As I look to the right of this typing block, I see that others have asked questions about it. I’ll answer one question. The Hotel (H) model version came out after the Delta (D) model and did see action in Vietnam, but only as a ‘slick’ or troop carrier. D models were never rigged for gunship operations. Only the B, C and M models with the single window cargo doors. H models had more shaft horse power and a bigger generator due to added avionics components.
I have watched several YouTube videos where this model has been built in either 7 separate videos, or one 30 minute video. In all of them scratch building is present due to model discrepancies. The pilot seats are wrong, worst modeling job on record. The 7 part series adds troop seats. Loved watching it, but you only see that in Apocalypse Now.
I just wanted to give my off the cuff initial opinion of the model as it sits in the box right now. The first thing I liked was that the company in Poland that manufactured it added a parts list and what the part is called. There are not 111 parts in this model. If you look closely, there are some numbers missing. There are 106 parts, most of them are unused weapons since you can’t mount all of them on the bird. Now some part names are vague. “Control Rod”. What it controls is not known unless you know your Hueys and once it is attached you go, “Oh, pitch control rod.” The pilot figures are just in a seated position as if both are wondering who is actually going to fly the chopper. One has his visor down.
The skids are warped. The guy in the 7 part series said they would be. Best you can do is clamp them down in perfect shape and hair dry them until the heat gets hot enough to limber them up, but not melt them. Good luck.
I have one observation. NEVER use your fuselage sections as a sprue. In other words, don’t attach other parts to the fuselage sections. Cutting away the sprue sections damages the fuselage. I know, there’s probably 40,000 ways you can cut away sprue racks and not damage the fuselage. Make it easy. Stop attaching sprue racks with parts to the fuselage.
Ok, two observations. Fuselage left, Fuselage right. Cockpit/Cabin sprue. Main Rotor parts sprue. Weapons system sprue. All the windows and clear parts were on their own sprue. For that matter, the blades, the transmission, the engine sections, all the rods, all on one sprue. Why is there a machine gun on the same sprue as the tail rotor? My point. Design the sprues in a method that allows us to find the parts based on the subject, not an easter egg hunt from hell.
Naturally this model has plastic mold issues. Teeny tiny parts are hard to file so I’m sure a fit issue is in my future. But I like it. I’m jazzed up to get started.
