I had a friend tell me that modelers are using Washi tape, which is found in papercrafting departments, instead of Tamiya tape. The vibe is that it works great and is cheaper. Anyone here have any experience with it?
I haven’t tried it but there’s a good video tutorial on Flory Models YouTube channel.
Hobby Lobby had it on sale last week.
I bought several rolls but havent tried it yet.
Come in really “pretty” colors!!!
What does Flory models YouTube video have to do with Washi tape? LOL!
Haven’t tried it but may check it out next time I’m at Hobby Lobby.
This is what it has to do with it:
Well, if he had posted the link… [:$]
Watched the review by Flory Models and it does looks promising.
I agree, it looks to be worth a try. Even if you still use Tamiya tape for the paint line, and use the Washi tape to fill in.
I actually watched that video just this afternoon and I think its definitely got some merit. It seems a bit “tackier” than Tamiya tape, but he says (Not putting a ton of confidence in that) that it doesnt lift NMF. I think some testing is in order.
Sounds good so far. I saw some on a clearance rack, which makes it a better value.
with all the tapes out there is there really a need for another tape on out bench? Is it that much better or that much cheaper?
No one is saying you have to own every brand of tape and have it on your bench. But, having multple brands gives the modeler a choice to which one best suits their needs. I see no down side to having more types of tape available.
When I was in HL last week, one of the ladies pointed me to the line of “Art Tape”. Blue crepe tape in 1/16, 1/8 and 1/4 widths, at around 2.49 a roll. The 1/16th is 603" on the roll. Got a roll of 1/8 and 1/16th to try.
Am using it on the mustang (Miss America) right now to lay out the red over the white, so we will see how it goes. Laid out nice and is easy to form curves with and you can re-lay it if you need to to adjust your lines, at least a couple of times. Will see how acrylics affect the edges and how it peels up. More later.
The well known 3M brand also produces washi tape. Seems here in the west it’s known more as decorative tape than as an actual brand?
regards,
Jack
I saw some yesterday that was made by Duck tape, too.
Just un-masked the red on Miss America. Came off nice and only pulled one small spot of white by a gear door (probably my fault not scuffing the primer in that spot. Pulled the white but not the primer.) Nice clean line, easy to remove. Recommend the blue Headline Sign Art Tape. Will have some pics of the red in the Mustang GB by tomorrow.
Did you happen to trim the tape down to thin width, or did you use one of the thinner tapes for the curves?
I had bought a roll of the blue 1/16" and 1/8". That was the 1/8 straight off the roll. Curves were big enough radius to get away with it. The rear scallops were pattern cut off the kit decals in Tamiya tape. I also used the 1/8" doing the blue, but should have gone with the 1/16" there as the wing curves were tighter radius and I had some cleanup to do on “blowouts” and creep under the edge.
Should have fixed the white peelup prior to doing the blue, and now have a big mess to fix as it pulled more and got into all 3 colors. Bad prep on my part, and not due to the tape- it only happened in the one spot.
Plane is 1/48th Mustang with wing clip.
Tried some of this last week and I like it!
Michaels sells a six pack of this tape that comes with a dispenser. The Tamiya tape will actually fit on this dispenser! Much better dispenser than the one Tamiya sells. You can fit 4-5 rolls on one of these.
