regarding Lam Son 719; CW4 (ret) Barry Martens wrote;
"We didn’t get assigned to the full operation on a big lift and stuff like that. We would fly the LZ prep and escort and then we would be off to Khe Sanh for fuel and rockets and on to the next mission. They had ARA bouncing around all over the AO and we would hardly ever come back to the same target right away after refueling. Another section would be inbound as we were pulling out. We’d brief them on the radio and then go on to the next mission.
We worked heavily with the ARVN’s on the firebases and scattered around on the ground. As you can tell from the other’s accounts and the record, there aren’t very many of those guys left to tell the stories. We would fly 10 to
25 sorties per crew during the daylight hours and then we had quite a few night calls. Nobody liked the night missions at all and we never really knew if we were doing any good or not. We tried to find the good guys and attempted to shoot where they needed the fire. I guess it was successful if there was anybody still alive in the morning because we managed to keep them alive through the night. It seems like Khe Sanh would get socked in just about every night sometime between midnight and first light. The fog would roll over the place and it would be zero-zero for several hours. If you didn’t make it back before the fog you had your hands full trying to climb out over the ridge and make it back to Quang Tri, already low on fuel. It was the longest 30 miles in the world having already flown 10 minutes into your 20 minute fuel light. You made one attempt to make it into Khe Sanh and if you didn’t make it you better sky up and head toward the beach.
There were many days where the smoke was so bad it was practically IFR. The smoke was from the bombing, artillery, rockets and all the fires we started.
We would have to climb out to 7,000-8,000 feet to get on top of the smoke and then spiral down when we reached the target area. You could work low or high and not much in between. Like I mentioned earlier, we had about 700lbs of fuel, 76 10lb rockets and whatever 7.62 and 40mm we could carry. That equated to about 45 minutes of air time, max. You hustled to the target, made contact with the ground guys, expended your ordinance and headed back for more fuel and rockets. We never brought any ammunition back. It was a full load each trip no matter what. If you couldn’t find your target or make your mission there was always somebody calling for fire somewhere so we had something to shoot.
At night you felt like you could walk on the AA fire. They had everything, 37mm, 57mm, 100mm and it was streaking into the sky in every direction.
Thank goodness they were mostly trying to hit the Air Force and Navy guys but, they usually had a few rounds for us. We were normally to low for the heavy stuff anyway and you just hoped you didn’t get in between them and the Air Force guy they were trying to hit. During the day, with all the smoke and haze, you couldn’t see the heavy AA fire and that was a good thing.
When it came close though, you could hear the rounds go by and going off.
Our biggest challenge was the smaller caliber machine guns, 12.7mm, 14.5mm and 23mm. You could not get low enough or high enough in a helicopter to get out of range. If you were real high they would not shot at you as much, probably because they knew if they waited a little bit you would come down lower, well within their reach. They were real good at setting up triangles of fire and drawing you into the middle gun and the others would open up when you started to break out of the dive. Pretty vulnerable when you were breaking out and it was up to the wingman to lay back far enough to cover your break with some good area fire. A good wingman could send a couple pair of rockets at each position in a few seconds if he was positioned just right. That would distract them long enough for you to turn away. If your wingman was a dork, he would be out of position, following your same path and then there would be nobody to cover his break. You just had to be in position to shoot all the time no matter who or what you were covering."
DAD
