USS Constitution build II - 35 years later
I built the Revell 1/96 USS Constitution over 35 years ago. Dragged a half-finished hull down to college my junior year (I was renting the upstairs of an old farm house) and brought home a nearly completed ship. My brother had to sit in the back seat of the car holding it during the 3+ hour trip home. Finally finished it in late 1983. It survived 2 more moves before finally being damaged beyond repair and scuttled. I did manage to save the stern and a few of the men, but that was it.
About 15 years ago, my brother found one at a garage sale that had never been opened and gave it to me, where it sat for the last 15 years. So I have finally opened the box and started in on it. Again.
Not wanting to repeat the errors of my youth, I did quite a bit of research, and came across Force9’s build. Impressive to say the least. Not wanting to piggy-back on his build, I decided to share some of my own parts of the build. I have decided to go with quite a few scratch-built pieces, and a few from ModelMonkey to help with the realism. I also scrapped the plastic, multi-piece decks for scratch-built wooden decks as well. I also have corrected several of the “errors” in hatch placements and added the walls for the Commodore’s area and pantry. Finally, since I am somewhat of a wiz with LEDs (I have been using LEDs to light pinball toys for the last 15 years), The berth deck and gun deck will be lit, as well as the Captain’s and Commodore’s cabins.
So join me if you want to jog down memory lane with me as I rebuild this classic for the second time.
Painted stern of USS Constitution
Bob
Hi Bob,
Your story almost mirrors mine regarding the ole Connie, in my case a ceiling register decided to come loose and fall onto the ship that was 90% complete totally destroying it, so I’ll be jogging down memory lane with ya.!
Michael D.
Michael: Happy to share the journey with you! [H]
So I have been busy for the last 5 or 6 weeks, so I have some catching up to do.
I started with the hull, and followed Force9’s lead to beef up the gun deck ports. I added a layer of .060 styrene around the ports and along the bottom edge where the final planks would go. I then added .040 x .125 styrene “planks” over the top. I left the bottom row off for now, so I would have a bit more room to slip the deck in. I plan on added a portion of the berth deck below that as well, but only in the areas that will be seen through the open deck hatches and ladder areas. Since it will be lit (dimly), I need to add this.
gun port 1st layer
gun deck planking
I decided to go with wooden decking, so I had to build some. I used 1/8" wide basswood strips and “painted” the edge with a dry erase marker before gluing together with wood glue. Held it all together with 2" wide masking tape spaced every 3 inches While that was drying, I started with the gun deck from the box. I glued up the plastic deck and traced it exactly onto paper, including all the deck openings. Using the drawings from the USS Constitution museum, I then edited the cutouts to better match the plans rather than the model’s version. I then traced this onto the wooden deck and cut everthing out very carefully with a new #11 blade. Finally, I added the gun stop around the deck.
making the wooden gun deck
I scratch built the necessary new hatch openings out of styrene, and cut out those from the plastic deck that didn’t need to be altered, and checked the fit. Finally, I added the board ends and nail holes with a small chisel and a T-pin. I then stained the deck “Early American” and gave it 3 coats of polyurethane (sanding in between).
stained deck
In between, I have been painting gun carriages, stairs, and most other parts needed for the early stages of the build. More to follow.
Bob
Great work on the deck. Individual Basswood strips seems like quite a daunting task.
I have quite a few photo’s of the Constitution, collected from the usual sources, and your deck color/tonality seems like a great match to the 2011 Change of Command event.
Here’s closeup from a Public domain pic:
The deck is a bit worn/dirty in spots. You can make out the 2 different “shades” where different wood was used.
That is very well done. It’s not so hard to go with individual strips. And the difference is remarkable.
Thanks Nino. Not so daunting once you get it all set up and get in a rhythm.
The color in your picture was exactly what I had in my mind’s eye.
Thanks GM. It makes all the difference. I also run a fine sanding block down one edge before gluing so that there is a distinct board edge. I also did the same with the styrene planking on the inner hull for the same reason. Creates a nice shadow line. For the plastic, I use a cardboard emory board my wife uses on her nails.
Bob
Needed bits and a stove, so I decided to try my hand at building one. I used an image of the BlueJacket camboose to get the size right, and then put this together:
camboose
Added the vent pipe as well, as the original kit version just seemed way too small.
I couldn’t decide on how I wanted to do the chain bits, so I made one of each. Finally decided on a hybrid - pair of each. Then I stumbled upon ModelMonkey’s 1/96 stuff and purchased his stove, some barrels, and the capstans. Since his 3D printing is clear, it seemed easier to light his stove, so I have decided to go with that instead.
Stove and chain bits
bit construction
final version
Moving on to bilge pumps next.
Bob
Luv, You do really beautiful work. I am anxious to see the hull when you get it painted.
Thanks Gene. Debating on whether or not to patina the copper plating. Seen so many variations on that, from painstakingly altering individual plates, to the generic green wash. Still haven’t decided on what to do. [^o)] Suggestions welcomed!
Hi Bob, I just found this thread and think you are doing a fantastic job. My first Constitution was with my father back in the late 60’s. He would spin tails of the old girl’s exploits while we built her. I have been tooking at the kit as of late to do her justice. I must say that you are setting the bar high. I don’t believe I could do as good a job.
I’ll be watching and taking notes.
Steve
This may be one reason why it takes me twice as long to complete something than I planned - daddy’s little helper!
helping nose
Thanks Steve. I definitely have a Type-A personality, and am a bit of a perfectionist, so once I have a goal or a picture in my mind’s eye (that I have usually pirated from the internet), I strive to get it to look like that. Did the same with all my pinball mods, which is probably why folks liked them as much as they did. My wife says I should have been an artist, but I am my own worst critic, and probably would never have sold anything due to my own stubborness.
Bob
So using the plans from the museum and many pictures from the ship, I started first with the copper portions of the pumps on the gun deck. I used plastic beads I purchased at HobbyLobby (a bag of 100+ beads of various sizes for $1.99) and selected six that looked about the right size. Painted them the metallic copper I used on the hull. But once I placed them next to the 1/96" figure, they just looked too large. So I picked out the next smaller size and that looked much better. I flattened the bottom with a file and added the outflow pipe and a base and repainted. I then built the pump handles and stands out of strip styrene. Painted that all black, and then added the “wooden” handles - painted 1/32" styrene rod. Set it up as in the pics and drawings - 4 on one set, and 2 on the other. Below is a photo of the set of 4 with one of the crew:
bilge pumps
And here is one on the deck with all 6 pumps.
pumps on deck
Hi;
I like that you said , and I quote " I am my own worst critic " ! I have been saying that for years ! To every modeler I talk to . You’r edition of the old Girl is awesome .I do like everything you’ve done to date . T.B.
Thanks for the kind words, TB. Here is a funny Calvin & Hobbs that pertains to this:
Calvin builds a plane
Started working on the spar deck walls last night. I am using .015 x .125 styrene strips (.156 for top board and trimming) for the planking. I tried .010 and .020 - .010 too thin, and .020 was tough to get the bolt pattern imprint through. .015 works great. To get an even pattern, I tried a 5/16" pounce wheel, but couldn’t get straight lines on such a thin width strip. So I made a jig out of .030 x .125 strip stock and drilled holes exactly where I wanted them, slightly larger than the blunted T-pin I was using to press into the .015 strip. Took a couple of tries to get the jig just how I wanted, but now I can press about an inch of strip stock per minute. Mounted and painted a few to show how it looks:
bolt pattern on main deck walls
Below you can see the thickened gun deck walls.
Sorry, but this Calvin is even MORE appropriate. He has caught the modeling bug!
calvin clipper ship
I know how he feels.
Yes, I understand completely! Except in the 1950’s the Aurora and other models I built were most likely under $5.00 [:)].
The sentiment, I believe, must be quite common among young modelers - and even much older ones [:D].
