Well the thing is that Liberty ships were not Navy ships and were built in various civilian yards all over the country.
Their paint colors didn’t really follow any uniform standard, topside Gray being the prime example. 5-O is pretty close usually, but any kind of red oxide on the bottom works.
Also the Trumpeter top bottom split is a little high up the sides.
And despite the comic pages, the decks on civilian Libertys are the same color as the verticals.
Thanks GM. That’s what I’ve gleaned from an old thread from somewhere that one of the crew of the O’Brien chimed in on. Also said the color split was at the 10’ line, and no boot. He added the top of the stack and upper mast were black.
Going to prime anyway as I had to sand the seam between upper and lower hulls.
Included in the Vallejo Nuclear Submarine paint set (71.611) is the Model Air Fire Red (71.084), slightly oranger than rusty primer red. I also like Reaper MSP 9242 Carrot Top Red.
Reaper’s Rust Brown (9072) is a bit redder, Auburn Shadow (9241) is a bit browner
They are absoluty not compatable. That’s my only beef I have with Mission. Thin with their thinner and clean the AB with watter. Anything else will break up the paint and you’ll have paint chips and specks to clog your brush. I have found that Vallejo thinner works ok. I love Mission other than that. It’s just not compatable with other acrylics.
