Takom 1/16 FT-17 Renault
Hi all!
This month I started a new challenge, my very first kit in 1/16 scale and on top of that from World War One, the Takom 1/16 FT-17 Renault! At first I was reluctant to choose this kit, since I have no experience on that scale and I have read about WWI in the past, but never work a kit from that era, so I’m on uncharted waters in many ways. I order the kit with a book reference which I receive from Spruebrothers in just 4 days! (consider that I’m out of the States in the Caribbean, Puerto Rico).
Started right away to look at the parts and get familiarized and also look at the information and pictures of the reference book. So I started now calling this a Char, not a panzer, not a tank, that’s the word for tank in French. Also found that this tank was call during WWI just as FT! The FT-17 name was later after the war due to the amount of variants and other French’s projects related. This Char was considered the first tank ! and was used in many conflicts and many countries, so I found a lot of references for the colors.
I started right away with the engine, at first the pictures were difficult to find, and even I confuse the American version with the french one.
The engine its just called 4 HP Renault engine, the american one is the BUDA HU engine.
The building its very straight forward, some cleaning is needed, but is minimal, the fitting is perfect. I added the cabling, the sparks plugs and some metal tubbing to represent it as much real as possible.
Renault 4HP engine
Primer was next in black and for that task I used Krylon black color in a can. The cover is great and its dries in 15-20 minutes.
The instructions give you a guide of color for the engine, but I used instead the pictures of the reference book.
Weathering of the engine started with a wash of black, then another with burnt umber.
Test fitting of the hull, always do this from time to time to detect any issue before you get to a more complicated stage.
Beautiful fitting, like a glove, and look at the size! okay is smaller than almost all the tanks but still is a great one.
For the next part I started weathering the engine compartment, I wanted to show a lot of everything but not in a exagerated way, so with that in mine I used a very fine wash of burnt umber to tone down the white, chipping and scratch marks using a mix of black and burnt umber applied with a toothpick, a fine brush and a sponge. Later I added stains and some 3 tones of rust due to water exposure, etc.
On the other side, that reside inside the tank’s belly, the story is a different one. The rust is not present, only stains, scratches and grime.
The driver floor also receive a similar treatment as the previous parts, except for the rust.
This recipe is repeated to the interior walls of the tank, then I added the pedals, the seat, and all the small details on the driver’s area, and glued in place the complete engine. Here I put one side to test again the fitting, and still perfect. A lot of retouches were done overall to match the tones between the parts.
Very nice work. The wear and weathering is top notch, and I love the worn paint on the gear shift. Just a thought…maybe add some wear to the pedals and the seat, depending if they are going to be visable after assembly.
!https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcQxgMpUYOoDHeW0aheJc1K22c8oLpRPUUXQLh56F9gMpwwogFk
What a treasure!
That motor is just awesome.
Really solid work so far. This should be a beauty in the end.
Turning out a nice bit of work on this beauty. 1/16 really is ideal for this particular subject considering how small the original is.
After inspecting the tracks vs the reference I found that they were casted and the textured was missing in my plastic kit. So for this task I used the Tamiya Thin glue and cover the whole track, then I used a stiff brush to tap all the track, showing the following result. ( I think I overdo this one, but the next ones are ok)
Nice work. I’m working through the Meng 1/35 scale version of this little jewel. Having fun with all the paint finishes. I also added wiring. Unfortunately, my reference was bad, so the little 4-cyl has 2 plugs per hole. Oh well, few will even bother to count, and I’m still having fun! You’ve added some very nice weathering effects.
Gene Beaird,
Pearland, Texas
Wow, I hope the engine hatch can be posed open to show off all that work you did, the engine looks so good I’d be tempted to display it beside the tank as a model in itself.
And nice work there on the tracks, that’s one of the things I always seem to overlook.
FT-17: gun barrel. I found that the gun barrel was wrong in shape in comparison with the book reference so I decide to switch to brass tube for the gun and for the sight. Also drill the hole for the periscope too, still need a flat ring to make a better look on it. Here you can see the results, I think they look much better. Next the turret!
Just finished the Meng version, love’n yours.
I’m still thinking in what colors & nation I would paint this fella.
I’m Between a Polish Version I found named “Janka” (take a good look at the wheels, they look like in bare wood)
or a postwar option in Japan under testing. (1919-1930)(type 79 Kogata)
For this one I was thinking to make the wheels in bare wood, and Kanji marking like the one done in militar weapons on that era.
With this Legend I can decifer the type of Equipment . For example here in the gun sight means " Type 44"
More evidence that this fella at some stage of production was used with unpainted wooden wheels.
And another good reference for the Japanese version. Look at the Kanji at the side of the hull.
Just a small update.
I remove the numbers from a sprue using a new blade and here is the result after applying it to the track.
Really nice work [Y]
And gee friggin’ whiz those wheels do look like unpainted wood.
