Takom 1/16 FT-17 Renault
I just received the last piece I needed for this work, the resin wheels simulating wood. Thanks Todd Michalak and Inside the Armour for a fantastic piece!
Starting the painting with a white primer, pieces are loose, just put it in position for the picture.
Following my previous work on a Sherman howitzer, I wanted to start the kit in Black & White too. This help me a lot to know were I’m going with the painting and weathering of the kit.
Here is the First Step of the Black & White process, started in white, then black for deep shadows, they will soften on the next steps, more to come.
I’m really enjoying this wip. Very nice work! gk
I ordered the resin to cast the wheels, but while waiting I wanted to experiment a bit painting the wood grain and see the results.
Started imitating the lines using a fine brush and Tamiya Linoneum deck brown xf-79,
Then I sealed using satin varnish so I can start with the first wash using black very diluted.
Here I experiment using filters of yellow and brown applied by brush, then another thinned black wash, and painted the metal parts.
For the base color I was looking for a inital color use in japanese war machines, Steven Zaloga have some articles about the theme, and also found some more inf here (http://matadormodels.co.uk/tank_museum/xcamo_ww2japan.htm)
So after a research I decided to go with a very light Olive Drab. So I use the Color Modulation set from AMMO for the task.
Here the results using the Basic Highlight Olive Drab.
Here some practice of the Kanji before applying it. Some retouches to the wheels, installed as well but not glued, only for fitting purposes. Also painted with a tamiya flat earth xf-52 the tracks to initiate a more weathered look.
Starting the initial dust using a mix of Tamiya Buff, Deck Tan and Flat earth. Still a long way to go.
Detailing of the layers of dust, dry and wet mud in process using the whole line of Dust & Mud from Ammo.
here is the progress on the tracks too, still in half-stage of weathering process, more details to come.
Also the side with the Kanji
Wow, that’s some sharp work! [Y]
!http://3.bp.blogspot.com/-KArhkEERXQM/UWK2Rhv-BBI/AAAAAAAADxo/AqLubxXmiqU/s1600/OMG+Chicken.gif
MARVELOUS!
Beautiful work.
thank you guys for all the great comments! I really appreciate it! I just finished the main weathering of the tracks & wheels, so I attached it to the hull. Some oils and wet mud also added, but I’m with mixed feelings, probably I make some minor changes to the actual mud effect. More to come!
Now 2 pictures of the full kit, still in progress, but almost done. Need some micro-detailing here and there and the base.
That’s just plain out cool. I love how those wooden front wheels came out.
Wow! The front wheels were wood?!? I didn’t know that.
Awesome work!
Gene Beaird,
Pearland, Texas
only at first were from wood, later you can find different type of metal version of the wheels.
Well the kit is finally done, only the wooden base is pending. I present you my version of the Japanese FT-17 Trainer tank during the 1929-1940 period more or less, using the Takom 1/16 FT-17 Renault. Hope you have enjoy the ride like I did.
Your weathering is top-notch. Just an all-around excellent build.
Just stunning, love what you’ve done here. And love that you can take the top off to show all the extra work you did on the engine and interior.
