Hello everybody!
Rob - I don’t think I’ll buy any aftermarket for this one. Let’s hope I can prevail in my OOB quest! As for the road wheel arms - it might as well be that there is a bug in the instructions. So far I have cut out one pair of those babies for a test fit and I hope I can install them correctly:
The rule I follow is: the arms themselves point down, and those little baffles point up. That should take care of it. I have the temptation to modify the stance of the tank to show it’s lowrider suspension in action. Trying to resist that, the decision still isn’t made. But I’ll be adding the wheels and tracks as a last step here, at least that’s the plan for now.
Real G - that paint scheme is a big reason for building this baby. But I’ll worry about the masking when it’s ready for paint. After researching the net I noticed that the C’s could also be seen in one-colour camouflage, so that’s an option for somebody that doesn’t want to do all the masking.
As for the accuracy of the kit - there are definitely problems with it. But nos as bad as you described them. Here’s a photo of the hull top against plans by mister George Bradford, taken from his book AFV Plans: Cold War Armored Fighting Vehicles, page 85. I have scanned them and scaled on my computer, then printed out:
As you can see the bins would be no real problem here, but the hull is a few mm short in all directions. It’s hard to say how this error came to be.
As you can see on the above photo I already made some progress. I have glued, filled and sanded the gun tube. I have primed it to check for flaws, but it’s all right, so I have dry-fitted it to the top of the hull:
I have read, that the fit of the sprockets to the hull stubs is a little iffy and I’m afraid the rubber trucks will pull on them, so I drilled the stubs out and modified the sprockets a little to mount them on an axle going through the hull in one piece. Maybe later I’ll find a nice metal 3mm axle (84mm long), for now it’s bamboo, still a lot stiffer than a piece of sprue:
The next one shows how I modified the sprockets:
I have also worked on subassemblies. The commander’s cupola is pretty complicated:
The MG (called Kulspruta 58 Strv - it’s actually an FN MAG) is still detacheable for painting. I have holowed the barrel out a little. And I’m very sceptic about the fit of the part on the right. Can somebody tell me what it is? Does it attach to the ammo box or not? I have also left out the commander sight’s window for painting. All the scopes lack armored “shutters”. Gonna have to do something about it.
Other subasseblies that I tackle right now: dozer blade and the stowage bins (fiberglass style):
There are also smaller parts and almost all of them need attention. I have hollowed out the tubes of the illum mortars (what a gizmo!). The small lights on the rear were plagued by sink holes, so I have drilled those sink holes out and plugged them with (stretched) sprue:
No I plan to join the hull halves, there’s a lot of filling and sanding to do there and I don’t want to break anything in process - that’s why the gun tube isn’t permanently installed yet. Thanks for looking and have a nice day
Paweł
