Substitute for Tamiya Acrylic Thinner
My quick Google search reveals that people use mineral spirits, alcohol and even windshield wash fluid as a substitute for the Tamiya thinner. Do they actually work? I don’t mind spending $6 per 250ml bottle, but if those substitutes work as good as the Tamiya thinner, I wouldn’t want to spend unnecessarily.
I have used regular Laquer thinner with good results. The 90% alcohol from Walgreens also works well.
Bill
Tamiya paints can be thinned with alcohol and lacquer thinner as mentioned. when using lacquer thinner, they spray really thin and translucent, building up color slowly. Just remember that Tamiya’s acrylic thinner also contains a retarder so if using rubbing alcohol to replace it consider using an acrylic retarder with it.
I’ve been using windshield washer fluid for years. As I understand it the fluid is just water with a small amount of alcohol added to keep it from freezing. The blue dye doesn’t seem to affect the paint, I haven’t tried the pink stuff though.
Heck, 99 cents for a big bottle is way cheaper than anything else.
I’m very intrigued by windshield washer fluid. Am I correct to assume that it does not leave soapy residue when the paint is cured?
…it doesn’t leave a soapy residue on my windshield! [^o)]
“…it doesn’t leave a soapy residue on my windshield!”
because windshield wipers wipe it?
I don’t think there is any soap/detergent in it. Or at least I’ve never seen what I use foam even when I shake it.
I think it’s just water, alcohol, and dye. You could make the same thing with tap water and drug store/chemist rubbing alcohol but it would cost more than the WWF.
Heck, give it a try, it’s not that expensive and if you don’t like it pour it into the WWF container in your car or truck… [:P]
ha - the wipers don’t reach the corners though do they? [;)]
I learned something new. I always thought the windshield wash fluid was soapy water!
I always thought it was a solution containing alcohol and ammonia. Like Windex.
Wouldn’t surprise me if there was a little ammonia in the mix as well. I’ll have to smell the windshield before I hop in the car tonight…
Without this hobby, I would have never ever paid attention to windshield wash fluid [:)] This hobby gives me never-ending fun.
According to Wikipedia, “The most common washer fluid solutions are given labels such as “All-Season”, “Bug Remover”, or “De-icer”, and usually are a combination of solvents with a detergent.”
I’ll just try it on some lego pieces.
Negative on the mineral spirits for Tamiya acrylics - the two will simply not mix, though it will work with Tamiya enamels, which aren’t available in some countries.
As already mentioned, Isopropyl and ethyl (denatured) alcohol will work. Arguably, denatured alcohol works better than Iso in some respects.
for tamyia acrilcs i use water very plentiful and free
I use plain old 70% Isopropyl rubbing alcohol, with a drop or two of liquitex “flow aid” mixed in for good measure. It dries really fast. $2 for a 32 oz. bottle.
HI!
I have found the BEST thinner for Tamiya acrylic is lacquer thinner. I use it all the time and it sprays great! I would use a better quality lacquer thinner if you can.
Yes water and alcohol both work, personally I’ve just had better luck mixing them together. The WWF is pre-mixed so I just find it over-all less trouble.
And yeah Tamiya does spray really well with lacquer thinner. I tend to use mostly Model Master since it’s the most available here. Not sure if it would work the same way or not.
Lacquer thinner’s all I use when spraying Tamiya. Thin with either Tamiya’s own lacquer thinner, or Gunze Mr. Leveling Thinner, then clean with Windex.
Thing I love about Tamiya + lacquer thinner is that you can reduce the pants off it and it still sprays beautifully. I’m increasingly subscribing to the “build up thin coats” school, and nothing does it better than Tamiya or Gunze + lacquer thinner. Model Master enamel does a passable job, but in my experience it’s tough to pull off with the “true” acrylics like Vallejo or Lifecolor.
Although it does have the advantage of being free and it does work to an extent, water is not great as a thinner for Tamiya acrylics. You have a higher tendency towards beading and running as the water has a higher surface tension and does not “wet” as well as alcohol or lacquer thinner. When airbrushing, the flat paints will tend to dry with a slightly chalky finish and some pigment separation may be evident (this is more prevalent with lighter colours) and this often presents as light hazy patches over the surface. When used with gloss colours, it will often dry with an eggshell finish rather than a nice lustrous gloss.
