First off Jeremy, “welcome” to this fun hobby and you have a good starter kit to try out there.[snWcm]
There is no need to start with an airbrush and basic brush painting is a skil that must be mastered in this hobby. Even if you get an airbrush you will still need to hand brush small parts unless you want to spend hours of time masking off small areas. The two techniques compliment one another.
Primer is not a neccessity unless you are doing multi media kits (resin, plastic, and photo etch), or painting strictly with certain acrylics. I am of the schoolof thought that, ‘if you dont need to use an extra step, don’t’.
Enamels vs Acrylics, each have their pro’s and cons and supporters. I use both, but for ease of use in the beginning, and especially for handbrushing, I would advise to start with enamels. Again, unless you are doing a kit with resin and photo etch, enamels do not need that primer coat that many acrylics require.
I dont own a shop compressor, but I suppose you can hook up an airbrush using a fitting adapter and some sort of regulator to dial down the air pressure.
In a nutshell, start simple and have fun along the way. Dont expect to make a contest winner in the master catagory on your first builds. Experiment with techniques you hear about, stay with and develop what works for you and dont worry about discarding those you do not care for.
Like anything else you do crawl, walk, run. There is a wealth of knowledge and experience here- ask questions, have a little patience for the reply(ies), and use what you can. Post pics if you have a hard time describing problems encountered.
I look forward to seeing that Airacobra. I have built many of those in the past 40 years [;)]
