Here it is! The 2nd round of the Carrier GBs. The rules are are very similar to those in round 1.
This GB will start today, on January 3rd and end on December 31st, 2014
extended until March 31st, 2015!
Rules**:**
Your project must be a plane designed to be used on a carrier. The particular aircraft you are building doesn’t have to be stationed on a carrier though (eg: a Corsair based on an airfield is completely fine).
The aircraft you are building had to be used in the Pacific Theatre of operation.
Aftermarket acessories or not, it’s your choice.
Crossovers are allowed.
Already started builds are ok, but please limit the construction to the fuselage halves being glued together.
You can continue your project from the previous round here (rule 4 doesn’t apply in this case)
6)The most important “rule”: Have fun!
Badges:
I’ll upload some badges soon. Feel free to add one to your signature as soon as you start your build.
Cheers, Clemens
