Orion Capsule and Service Module 1/25 Scale
Just about complete. I added logo decals to the capsule, under the service module rim and the No Step logo. In the first picture you can also see what I am calling the Load Points, 6 small tabs that show as black when in space.
Well, the model is now complete, but not correct. Everything is pinned such that it all lines up except for the crew module adapter to the service module body. The mistake I made is that there is a bump out (not sure what it does) on the underside of the crew module adapter that should be off center (see arrow). I lined it up vertically which means the crew module is off center. DOH!!!
Anyway, here is the completed, yet misaligned model. I will have to reprint all of the service module except for the solar panels. I will also change the service module body and crew module adapter so there an indexing tab.
Very impressive model! It’s looking good.
Here is a 3D printing how to. I am reprinting the service module parts to align correctly. The slicer I use defaults to two layers on this slanted side and I forgot to up that to three layers. Had to reprint this part. You can see the results of 2 vs 3 layers.
This looks great! Where did you get the 3d files from?
I made the model. It is now complete and I am about to publish the parts. I will post a link once the model is published.
The model is now finally complete. The alignment problem has been fixed, I added alignment tabs.
Here is the published model if you would like to build one yourself.
https://www.printables.com/model/1901151-orion-capsule-with-service-module
Thank you very much for sharing, much appreciated!
Btw, turns out I had put already followed your work on printables when I came across your Apollo launch tower. Tremendous piece of work there.
The big question is, does it fit on your bookcase shelf?
Well, It would fit if you printed the solar panels in the stowed position and used the vertical stand. I chose instead to use the unfolded solar panels and place it on top of the bookcase, a much better looking model.
Absolutely fantastic work!!
