Space…The Final Frontier!!!
These are the voyages of the NASA Rescue M113. Something different for the old APC.
I will use an Italeri M113A! kit. First I assembled the base internals. After, I gave them a coat of Tamiya Cockpit Green (Vomit Green for those who spent time inside one) and the floor plate painted with Alclad Brushed Aluminum.
The kit decals were not correct so the decals on the engine compartment door were custom made.
Next I assembled the internals into the hull section, finished adding the smaller parts, added some scratch wiring and a scratch wall mounted radio switch. The actual NASA M113 has the center post and seats removed for more space to move around in full space suits.
I weathered the internals with Burnt Sienna oil washes and MIG pigment Urban Dust. The compartment latches were painted with Alclad Steel
The roof panel I added the hand straps made from some leftover PH and a cable which runs to the rear. The latches and pull cable on the back rectangle hatch was drybrushed with Alclad Steel. Then the roof was weathered with Burnt Sienna oil wash.
With the interior complete, the top sections are assembled. The M113 panels have a fillet type weld. Where the seams meet I used Mr. Surfacer 500 to lie in the seam and simulate the fillet weld.
Some of the side panels had areas with sink marks which were also filled with Mr Surfacer. All the road wheel axels and front drive sprocket were also assembled.
That’s where I am at for now. Time to put all the little detail parts on the top section, work on road wheels and yes…tracks.
All comments are welcome, thanks for looking.
Rounds Complete!!
