Following Michael “165thspc” Koenig’s excellent [url=]M1120 LHS build[/url] at Armorama has inspired me to start a project I have been thinking about for a while. I have begun to convert the Trumpeter M983A1 tractor and parts from the M1120 LHS into an M1074 PLS.
I have been collecting the parts since the M1120 LHS came out late last year. I have collected both kits, the Real Model M983 engine set, tires and wheels from the Hobby Boss M1070 HETS, and additional axle and suspension parts from Accurate Armour’s M1070 HETS kit that I ordered from Accurate Armour.
Here is what I am building, an M1074 PLS (Paletized Load System)
So far, I have started by lengthening the frame to the 35’ 6" full length of the PLS. I used two frame sections from the LHS kit to do it.
A note on the Trumpeter kit, it is awesome. So far, it has both front steering gear boxes and all linkages. Also, the transfer case is angled as it should be. Its looking good so far.
Thanks for the support guys. I have been working on this most of the day today, gotta love 4-day weekends in the military.
I completed the frame.
Here is the front axles. I cut the gear reduction parts off the front differential and replaced it with a non-geared diff cover. I also added the Real Model front air brakes. They look very good. Trumpeter provides the rear air brakes, but missed the front ones. The front wheels are steerable as well. Trumpeter did this area really well. I am waiting to position the wheels until later when I will attach the steering arms as well.
On the rear, I scratched the mounts for the middle axle and used the swing arms from Accurate Armour. I placed the rear axle from the kit in this position. For the rear axle, I used the Accurate Armor axle which is steerable and does not have the gear reduction. The rear axle also has steerable wheels which will be adjusted and set later as well. As luck would have it, the drive shaft needed to go between the third and fourth axle is the same length as the kit driveshaft that goes from the transmission to the transfer case. I was able to use the kit part as there is a new transmission to transfer case driveshaft in the Real Model Engine set.
One issue I found last night after I posted. It is amazing how you always find flaws when you step away from the bench and see your own pics, for me anyways. I felt like something was off, but couldn’t put my finger on it, then I saw it. The suspension parts (swing arms and air bags) for the third axle were on backwards!! DOH!!! I guess I was looking at my references wrong or something. The pivot point should be at the front (left in previous pics) and the air bag should be to the rear. I was able to cut it all away and swap everything around. Here is the correct configuration.
Hopefully I will keep everything straight for the rest of the build.
Thanks Pawel for following along. I am really enjoying this build.
I got some more done today. I worked on the engine compartment. I decided to build it closed and just use the Italeri engine blank and added an oil pan to fill the space if it is seen from the underside. The rest of the engine is covered by panels. I also started on the accessories mounted on the fenders. Here it is so far (the cab shell is just in place to get some sense of scale).
Work continues. I have completed pretty much all the PLS conversion. I need to start on the cab and finish it up.
I was planning on it being an M1074 with the Materiel Handling Crane (MHC) in front if the hook for the flatrack. I have an Italeri crane, but I couldn’t work out how to fit it there. The crane mount is different, and apparently so is the crane and outriggers. I have decided to now make it an M1075 (w/o MHC). In place of the crane, like on the M1120, is a work platform.
Here it is. I completed the air cleaner and hydraulic fluid tank as well as the exhaust and spare tire rack and hoist.
I also have completed the lift mechanism for the flatrack. The rear hinge on the lift plate was a pain. Italeri molds it as an open clip that is supposed to snap onto the hing point at the base. The open hinge kept popping off. I ended up cutting the open hinge off and replacing the ends with resin scraps and drilled a hole through each. I then pinned the hinge point to make is secure and still working. I don’t know why Italeri engineered it that way, but it sucks.
Here is the fuel tank too. It was made by using a couple end caps out of 0.040 sheet styrene and then wrapping 0.200 styrene sheet around them to form the outside. The step on it is left over diamond plate PE.
I also added the rear steering gear and drive shaft for it.
Somehow I missed your thursday update - and there is some great work shown there! Like I already said I like your work on the chassis very much. Some say it won’t be seen much but for me it is important to be able to see those details, thay just define what the truck really is. Nice work on the cab, too - good luck with your projects and have a nice day
Thanks Pawel. It has been a fun build so far. I have done a bit of work over the weekend. I finished the cab extension and modified the front plate by closing off the grill opening, adding an opening for the blackout drive light and horn, and adding an access plate and new clevis attachment points.
I also couldn’t admit defeat on the Material Handling Crane (MHC) and not make an M1074. The M1074 w/MHC is the type used by Artillery Bns as an ammo supply vehicle and that was the type I originally wanted to build. I took another crack at the crane and realized I had the front mudguards, fuel tank, and BII box too far forward. Once I relocated these items back to the proper locations, I had enough room for the MHC. Here is how it turned out.
I also set the turned wheels and added the tires. Here it is overall at this stage.
That pretty much finishes all the M1074 PLS conversion parts. Next up is the cab interior. The work continues…
I did not get a lot done over the last week or so. Work has been hectic. I did complete the interior. Trumpeter did an excellent job here. There are also a bunch of decals (placards, instruments, etc,) for the interior. I rebuilt the rear wall sound-proofing/heat shield using A&B putty.
The door panels are fully detailed, even down to the opening for the lock striker on the side.
The seat and their bases are also nicely detailed.
I added back some rivet detail (black dots) lost when sanding the roof for the extended cab. I used Archer rivet decals for them.
She’s lookin’ good. I’ve been impressed by the more recent Trumpeter stuff I’ve built.
How did those Archer rivet decals work out for you? They look pretty good. I bought some for a couple of ancient aircraft kits with about a zillion surface rivets. Guess the sensible thing would be just to sand them all off but I figured I’d just build it as is.
Hi Gamera - Yes, Trumpeter’s newer kits are great. They do really well on their trucks. The Archer rivets work pretty well. They are fragile though and I seal them with clear coat once they are set. I would not want to do a whole fuselage of them though.
Thanks Gino, thankfully I don’t figure I have to use many on the plane. I just want someone to fill in the areas where I sand the top and bottom of the fuselage.
I have completed the interior painting and decals on the cab. All the decals are from the Trumpeter M983 kit. They are quite complete and look very good. I replaced the kit radio with a SINCGARS ASIP, handset, and speakerbox from the now-OOP Pro Art set. I am glad I have a few of these since no one else makes just a SINCGARS set.
