Japanese Group Build XIV (2025)
@fjs3 Great work on your Zero. The chipping as @dadoffour points out is very well done, as it is possible to overdo that effect (to the point that someone saw a Jack I did like that and suggested it needed some paint).
Thank you so much for the kind words!
Thank you Aggieman,
I always try to keep weathering to a minimum, unless the aircraft was really that banged up. In the words of Shep Paine, “Less is best…” Weathering is easy to overdo. You can always add more if you think it’s necessary, because it’s a lot harder to fix once you’ve crossed that line.
Thanks for the kind words, Sir.
@fjs3, Very nice looking Zeke ! I’ll get the roster updated with your latest addition.
Love this zero! Very nicely done.
Great looking zero. The paint and weathering is flawless. Thanks for sharing.
Time for an update on the Raiden…
The eBay purchase arrived and I took time tonight to put the decals on and remove the masking from the canopy.
I still need to add the antenna wire and weather it. Will probably stick with light weathering.
Nice job. That’s Sadaaki Akamatsu’s mount. Colorful character if you care to look him up.
Looks great. I think you are correct to go easy on the weathering as these aircraft did not serve outside the main islands as far as I know.
But there are always exceptions…
Ok, I’ve finished my little 1/48 Rikuo Type 97 motorcycle - Hasegawa kit. The standing figure is from Tamiya newer Zero fighter kit. It pretty much out of the box, except for the MV lense headlight, and the brake lines and small pipings added. And it helps if I post it in the correct Gb!
Excellent work @waikong ! You get bonus points for adding/painting figures :clap: :clap: :clap:
Is this like Who’s Line, where the points don’t matter? Or do I need to up my game again?:thinking:
No, That’s just me trying to sound original in my replies. There are no actual points in play here :crazy_face:
I was trying to be funny. It doesn’t come across in the text.
Damn, I thought I was going to get points!
Bonus Points GIFs | Tenor
Here you go!
I can give you 5 of my MPC Golden Opportunity Kit tokens :grin:
Just popping in because the rumor on the street around here is someone is handing out points…
