I have to presume that more and more people are using exam gloves while painting if for no other reason then to keep their hands clean. Does anyone use them while gluing a kit as well? If so how has it gone?
In using during gluing I can also see them helping to keep fingerprints in the soft plastic. As well as of course keeping oils from one’s fingers off of the model as well.
And if anyone has used gloves while building which type of glove is recommended?
you cant feel anything when you have them on. Holding a model during painting is one thing, gluing small parts would be a problem. I always clean the model with alcohol before painting anyway.
I wash in soap and water when I start a kit but there after I use the alcohol because it drys faster than water and then its ready to paint. You can even speed dry it with the airbrush.
I’ve been using nitrile gloves lately for spraying and when handling nasty solvents.
I tried them a couple times for gluing, ended up with same conclusion as Bill, couldn’t feel anything, didn’t work.
I’ve tried tight-fitting surgical gloves too. Better, but still don’t like the lack of ‘feel’. Wonder how long it takes surgeons to get used to them? They so some fairly delicate work, too.
Thank you for the clairification. Right now do to cost, space, and pets (one Cockatiel and one Tarantula that would NOT react well) I do not currently own an airbrush.
That was my first thought. Wear exam gloves of some sort while either brush painting or airbrushing to keep one’s hands clean. Making personal cleanup that much easier.
I find two types of disposable gloves in my local hardware store. First are the latex stretchy ones we have been talking about. The second are referred to as painters gloves, just two sheets of plastic film sealed around the edges. They fit much more awkwardly than the stretchy latex type, and are terrible for doing any thing but holding a model or part while you are spray painting it. But- they are cheaper than the first kind, so I occasionally buy a box of them. I keep both types on my supply shelves.
I use the latex exam gloves that are used in doctor’s offices. You can find them from several sources. The “heavier” grade cleaning type are not worth it IMO as you do lose the feel. The thinner surgical grade ones are really good. Of course if you are allergic to latex then you would not want them.
Those almost sound like the type of gloves that food prep workers wear nowadays. More than once I’ve had to laugh when I see someone attempting to make a sandwich while wearing a pair of “oversized” gloves.
I’d have to agree with you that the heavier grade gloves wouldn’t be too useful to us. And I also agree that the thinner surgical gloves would, because of the delicate work of doctors/surgens would be the better option. Think of the work a doctor/surgen is doing when they operate.
Although, I can tell you from experience as a Medic in The U.S. Army that neither exam or surgical gloves can be easy to put on. And that they do take a little bit of practice to do so.
Those white cotton gloves are standard equipment for people who work in museums. A competent curator or conservator instinctively puts on a pair before touching an artifact, to avoid fingerprints.
For model work I find them more of a hindrance than a help. In addition to the aforementioned lack of “feel,” the rather gauzy texture of the glove fabric snags on details. When I was working in a museum, my boss and I had a discussion about whether the curatorial assistant and I ought to wear gloves when we worked on old models. I talked him out of it. (He was, in most respects, a reasonable man.
Nowadays I keep a package of pre-moistened baby wipes on my bench to keep my hands clean. Be warned: never use a baby wipe to wipe up a CA adhesive spill! I almost sent myself to the emergency room that way once.
