Hey guys,
Made some progress last night, as I had trouble sleeping.
I want to get the engine done so I can get the interior started when I get my kit in a day or 2. Yes…I found the old DML M1A1 kit that includes the interior stations on eBay. it was only $15 bucks!!!
Anyway, onto the build log!!!
I have mixed feelings about the engine kit - Legend part# LF1028
There are many shortcomings, but on the other hand, I have found it easy to modify, change, destroy [:P]
I had some fit issues on the right hand side with the turbine drive conversion and cooling system.
Note the obscured airholes beneath the screen (just some scrap PE screen my local hobby shop had as a discontinued train item).
You can also see my handy work on the air intake/filter system that was non-existent. I ended up pulling out what I had completed and repositioned some things to get a much better fit.
NOTE the WARPING of the top hull plating. Must be the change in weather. I had to move up from the basement until I get a space heater down below in man town!
Any tips for dealing with warping polystyrene? I figure the glue will hold it down when I attach.
There are many more choices to be made in regard to the engine, however, it all comes down to how MUCH time do I want to OR CAN give to just the engine. At a minimum, I intend to add some line colors and connectors that more accurately reflect the real thing. Not sure I want to spend the time building out the back exhaust port. It is SO FAR BACK it is making me mental. Plus I have to redo the aluminum finish.
Finally, I am going to start painting the tracks (AS SOON as I get my heater downstairs so I CAN paint). Then I expect to have the interior pieces to get the drivers station in to complete the hull.
Not only am I excited to be making some progress, I am going to be in an Auto GB starting next month that I want to be able to focus on without taking away from this major undertaking.
As usual, thanks to all for following and supporting.
Ken
