With the holidays and life in general, bench time has been pretty limited as of late. I have started a new project though.
I am working on a destroyed T55 somewhere in the Middle East (Iraq maybe?). I intend it to look something like these; with the turret separated from the hull from a catastrophic ammo explosion.
I am using Tamiya’s T55A kit.
1080×810 64.9 KB
I am adding a whole bunch of left over parts from MiniArt T54/55 kits that I have built and acquired. These kits have a bunch of leftover sprues with lots of parts ion them since MiniArt mix-and-matches sprues to get the different versions. An example, just one kit.
999×750 117 KB
I am also using the Mig T55 Burn Out resin set.
Here it is so far. Tamiya parts are dark green. MiniArt parts are gray. Mig’s parts are the cream resin ones. White is scratch parts by me.
Next up is some paint on the interior, then working on the exterior. I will be replacing the fenders over the tracks with pieces from MiniArt, as well as most of the fittings and fixtures on the exterior since they are superior to the Tamiya parts. Roadwheels will be a mix of the Mig burned out ones w/out rubber and some left over Verlinden ones with badly worn rubber. More to come soon.
Oh yeah, that will be a good one! I have to show it to my friend who was a T-55 tanker back in the early nineties! Maybe even he could help you, should you have any questions.
At work he told us how he got a really nice place to sleep, atop of the personnel heater, because he was the only one short enough to fit there!
There was a cartoon of Iraqi tank commanders recieving flight pay because their turrets would launch when we hit the tank. That was during Desert Storm aboard the Ranger no less. Neat project.
Thanks all. I have been working on it a bit more. I decided to change tack on the engine. Instead of the solid, drop in engine area from Mig, I had a MiniArt T55 engine as well. I built up the MiniArt engine and modified the hull to fit it.
I also made the rear wall out of thick aluminum foil and destroyed it as if it was in an internal explosion. I made it by pressing the foil down over the kit part to duplicate it. I also punched holes in the driver’s wall and the tank on the right side wall.
This is how I am sort of seeing the final product, something like this.
Next up is to start the burned-out, rusty, sooty painting process.
I have finished the interior painting and finishing. I added some loose debris inside; empty shell casings, wire, ammo cans, and various bits and bobs. I sprayed a thin coat of a rust color overall, then liberally coated them with rust colored and black pastel chalks.
This is what you will see w/the hull closed up. I plan on leaving the deck plate over the engine off and thrown to the side a bit mangled. The right rear door over the cooling fan will be blown open, and the upper grills will be blown off/opened as well.
On to the turret. I added some wires and then gave it the same finishing treatments as the hull.
Next up is to add all the exterior details…then destroy them.
Side bar please; can anyone tell me the diameter of the actual external fuel tanks on the T-55. length is not an issue, but I could really use the diameter dimension; inches or metric works. I can recalculate as needed.
