Completed Redo of Tamiya 1:32 Supermarine Spitfire Mk. VIII
To my fellow forum members,
This particular build took me a little longer. I was having some difficulty with my memory and it took me awhile to get back to normal. Mrs. Toshi said it’s just old age. LOL!
In finalizing this build, I AB a coat of grey for the bottom of the Mk VIII. Then with a free hand I AB the gray/green camouflage. Once that dried, I used the Testors CreateFX brown, gray, black, and natural stain overlying each other to give the weathering some depth. I then went back to a technique I haven’t utilized since my first build, a P-61.
I added the salt technique just to see how the outcome would change the weathering. If I didn’t like it, I could always re-shoot the camouflage. I didn’t mind doing that as that was really fun. Overall, I think it turned out ok. Please see the photos below, thank you!
Toshi
A fine looking Spit, Toshi. Another notch in your building belt. Nice work on such a huge kit.
BK
Another beauty Toshi! Those 1/32 Tamiya’s look sooo nice! On to the next:)
Very nicely done Mr. Toshi ! The hand done airbrushed camo looks spot on, very curageous of you not to use masks but you pulled it off well.
Pretty darn cool Toshi, looking forward to your next build!
Thank you very much gentleman, I highly appreciate the praise and the read and reply! As I mentioned above, this build took me a little longer than anticipated but it worked out well in the end.
Next up? Monogram 1:32 F4-G Phantom II Wild Weasel.
Another vote for a GREAT build and finish. Ya’ hit her outta the park, Buddy, (or in your case a touchdown.) (****:>)
Really nice job Toshi, thanks for the WIP and photos. I’ll be watching for the F-4.
Patrick
Nice work Mr. Toshi! Wow, a 1/32 F4? You must have big hanger for all these large scale birds.
Thank you sir, no big hanger. Just a very understanding Mrs. Toshi! LOL!
Nicely done Toshi. Another build to add to your growing collection of dream birds. :slight_smile:
Thank you sir.
Toshi,
Your Spitfire looks really great! One can never have enough Spitfire kits on the shelf…Douglas
Thank you sir, it is my pleasure. As for the WIP, this helps me stay on course with forum members help.
Toshi
This build turned out fine. It’s the finish that I was most disappointed. I messed up on the salt technique. So instead of tossing this build, I decided to see if I can fix it or not.
First off, I sanded everything off that was affected by salt. Krylon Primer from Walmart and Model Master paints from Hobby Lobby. I have a seller on eBay that has the entire decal set from this kit. With this knowledge, I’ll try to fix things again.
Toshi
Sometimes repaints can be very satisfying, my friend. I’ve done more than a few myself. Its nice to go back with a new bag of tricks and I’m going to relish this thread knowing how well you can re-do this. :slight_smile:
+1 above.
I remember a TF-18A/FA-18B I built in the 90s. I experimented with a new flat clear paint I got a hold of, ended up “snowing” the bird white (its the excessive flat base drying up white). Let her sit a few months and then did a repaint.
This plane was built in June of 2015. It kept bugging me to be repainted. I was not too happy about the weathering effect. While I’m in between builds, I figured that this would be a great opportunity to clean it up. Thanks for following!
Toshi
I’m hoping that this redo will fix what’s wrong. Thanks.
Toshi
