I received my Renegade “Velocity” a few days ago. Since then, I’ve had the opportunity to put it through some paces. I’ll give you my opinions. I’m anxious to hear yours.
Construction: On first opening the package, I found a well made storage box for the AB. While the box is very nice, I think it’s a bit of overkill for me. I don’t keep my AB’s in their boxes, so having a super-nice storage box is, in my opinion, a waste of money. I’d rather see those dollars put into other aspect of the brush. (More on that later.)
The Brush: The first pics I saw of the Renegades showed them in chrome covered brass. The brush I received - and I assume it’s the same for all of them - is in a gun metal finish. Unlike the photos, on the barrel, behind the color cup, is a flat section that has “Velocity” stamped in it. All-in-all, it is a very attractive AB. I like the finish and believe it will be less prone to showing smudges, etc. Note: I go overboard in cleaning my brushes, So, for some people, I understand that this wouldn’t be an issue.
Accessories: The Velocity comes in the case described along with a small plastic container that holds an adapter to allow the use of and Iwata air hose. There is another small part in the plastic vial, but I can’t tell you what it is for. I have used the adapter, but I couldn’t find any use for the small “part.” Maybe someone else will know what it is for. There is also a set of minimalist instructions in the box. By the way, the Velocity is the gravity feed unit. The Rage is a bottom feed unit and the Spirit is a side feed unit. Both come with a few more parts.
Hooking It Up: As stated, I use an Iwata hose. So I made use of the adapter that came with the Renegade. The adapter has a female end that screws onto the smaller Badger male end for air. There is no (at least in mine) rubber seal in the adapter. I attached an Iwate male quick release fitting to the Renegade adapter. That came with a rubber seal. When I put it all together, and hooked up the air line, there was a noticable hiss of escaping air at the connection. It turns out that it was due to the fact that there is no rubber seal in the adpater. it was easy to fix, however, using a small piece of teflon tape. Reinstalled with the tape and there is no air leak.
Initial Impressions: This a very good value when it comes to dollars spent vs. painting quality. The trigger action is very smooth and easy. Not as soft as my Harder Steenbecks, but better than by Iwata HP-C. There is an adjustable trigger stop for paint volume at the end that responds very nicely. The AB allowed me to paint a very thin (not quite hairline) line with virtually no overspray. The Velocity comes with a .21 mm needle. Personally, I think this is a good compromise size for an AB. I have a .15 mm, a .30 mm and a .40 mm. In my opinion, a .40 mm is great for general model paint application, but too big for very fine spraying. A .15 mm is great for the very fine work, but will take forever to lay down a lot of paint for a base coat. If you’re going to have one AB, then I would reccomend a .21 to .30 mm needle. I believe that the Rage comes with a .30 mm needle and is a bottom feed unit. The paint cup on the Velocity is permanently attached and seems to be about 1/3 ounce capacity (9 ml?).
The Not So Good: A few things… The paint cup cover is plastic. I don’t care for that at all. This strikes me as a very good quality brush, and to provide a plastic cover strikes me a cheap. Besides, my plastic cover is already loose and prone not to stay affixed to the paint cup. I tried the metal cover from my HP-C and it fits perfectly. In short order I will order an extra HP-C cover and put the plastic one in the fancy box that I won’t use. I would have rather seen Badger use cardboard for the box and use the money for a better cup cap. Be Aware, the nozzle tip is TINY, TINY, TINY! The first thing I do with an AB is take it apart to see how easy it will be to put back together after a good cleaning. When you get to part No. R-003 (Ultra Fine Tip) make sure that you remove it in an area where it won’t get lost. it is small and could very easily be lost. I will probably order an extra nozzle and needle very soon just in case of loss or damage. Because of its small size I suspect it will be very difficult to clean. That could present problems after more usage and require replacement. We’ll see. Finally, the instructions are nothing. This is not a big issue for me, as I’m comfortable taking a brush apart and putting it back together without instructions. However, some may find this lack of information a problem. If Badger wants to sell these to new airbrush users, then I think they will have to provide more information on the brush, its use, its break down and its clean up.
I don’t think the brush is as easy to clean as my Iwata and HS’s. Not a great deal more difficult, just not as easy. This goes back to the tip size for me. It’s just so small that it’s difficult to work with. The needle seems to be of very good quality and comparable to the other brushes that I own. For some people, the fact that the paint cup isn’t removable may be an issue. I don’t care that much and the size of the cup does make it easy to clean out.
Overall Impressions: I paid $105 for my brush, including shipping, from Bear Air. I understand the suggested retail for the brush is about $165 and many places seem to be selling it for about $155. I don’t know if Bear Air’s price is permanent or not, as I was informed that they got a large number of them from Badger at a good price in order to “prime the pump.”
I got my Iwata HP-C for $165, less shipping. So, I would say that $105, the Renegade is a better buy. Based on my inspection and limited use so far, it is at least as good of a brush as my Iwata HP-C. If the price settles in at the $145 to $155 range for the Renegade, then the value benefit will diminish. As far as I can see, this Badger is aimed directly at the Iwata HP series of brushes. They look very similar, have similar weights and features, and spread paint as well as the Iwata. If the market price of the Renegades stays at around $100, then Iwata will have to reconfigure their pricing accordingly.
The Velocity is, at this early stage, a very good brush. I think that Badger has done a very nice job putting out a high quality product at a very good price. I’m looking forward to using it a great deal more over the next month or two to see if it continues to operate well and the parts and finish hold up to continued use. A few minor early gripes. but all things that are fixable or can be overlooked.
I’m looking forward to reading other people’s impressions of the Renegades.
