I’ve finally gotten the fuselage & wings together on this “Styrene Colossus.” I glued the fuselage & wing halves with Tenax, moving at the blinding speed of about one inch at a time. The fit was great. I only needed a touch of CA on the bottom of the rear fuselage for a hairline gap. The turret & sighting fairings also needed a touch, and the compound curves were a beast to sand & polish. I’ve done the fairings on the lower fuselage, just have the upper left to do (Got to take a break sometime !) The raised panel lines that got sanded were replaced by drawing the edge (not point) of a # 11 blade. It leaves a raised line on each side of the slice. I don’t think it will be noticible.
Here’s a shot of the gear & bay doors & retractors. The engines are nice for one-piece. The main gear were difficult to clean up. The cowling on the left has been “re-riveted,” as these really show on the actual AC.
The gear bays are also nicely molded. They’re almost as crisp as resin !
Well, I may have to make a trip to Home Depot to “Get a Wagner” to prime this beast. [(-D]
