Thanks Mel, if I knew what the push pull tubes were I would. Lol. I’ll check the sprues when I assemble the rotors, they’ll be one of the last sections I build.
Anyhoo I had a further go at getting the fuselage halves fixed up so they hold together this morning, I would have done some more, i.e. some of the interior also, but light is fading here in my part of the UK due to some rather ominous looking clouds overhead, and it’s only just gone 13:00!
Pics -
Forgot to take a pic of the other side where I’ve put the engine cover door on, nice idea to have it open but I’ve chosen to have it shut and glued it in place. I thought about fixing it on using magnets so that I could have it open or closed, but I think it’d be too difficult to fit the magnets in place, if they’d even fit when the interior/engine is in place.
Did a dry fit with the interior roof/floor/back wall and it will fit without causing more of a gap, unlike the ESCI UH-1D interior, but I’ll have to remove the magnets that hold the front of the roof in place and I’ll have to use the interior roof piece (the ceiling I suppose you’d call it) instead of the plasticard strip I put in to get some sort of level roof. The roof on the left half of the fuselage does seem quite warped in my version of this kit, without the 2 magnets in place to hold it the left side is slightly raised up at the front and the intake doesn’t meet the same part on the other half of the fuselage, the two halves of the roof only seem to meet properly in the centre!
Not happy with the stabs, they were a tight fit and don’t seem to have gone on level.
I wasn’t too happy with the tail fin assembly either, it doesn’t seem to quite fit properly (I taped it up to dry fit it as one piece and there was still the slight ridge on one side where it joins with the tail boom). Not sure about sanding that down though, I’ll lose detail if I do. I will also hopefully be able to close the gap at the back of the tail fin by adding a 2mmx1mm magnet towards the back end of the tail fin.
Yes there’s a gap down the middle of the fuselage, but I have an idea I think I might try - build up some Mr Surfacer on the edge of 1 of the fuselage halves, then sand it down on the outside where necessary so the gap is lessened, I haven’t painted the fuselage halves yet so I won’t be ruining the paint work. Don’t know if Mr Surfacer will adhere to just one edge though. Have to see how that goes…
The currency you see in the pics is just 6 British pennies to weigh the model down on it’s skids, otherwise it tips up, I’ll have to glue them to the underside of the interior floor when I’ve got it built.
Overall though this is going quite well so far, despite the poor fit around the roof and the intake area and the stabs going on a bit skewed.
