Well, I’ve popped up again tonight.
The bad news is that I spent most of Saturday & Sunday !http://www.smiley-lol.com/smiley/loisirs/dehors/elmer.gifhunting for my SD card with the pics I was going to display from Tuesdays doings… alas, no !http://s2.rimg.info/544a45dd176f55d1bf6564214a21a675.gifduck… er luck.
But the good news!http://emoticoner.com/files/emoticons/smileys/feed-birds-smiley.gif?1292867592 is that I have today’s picture updates, guess that’ll have to do.
Exhaust (not adjusted yet) pipes
peeking up through the exhaust vents and some of the surface texture showing on the armor surfaces.
!http://pic100.picturetrail.com/VOL351/12291693/21864322/413474780.jpg
Here is the rear deck with a more detailed look at the exhaust area (dark & dusty) and the grill support partition installed between the arrow symbols going from left to right.
Now without the SD card I have to move on past some work already completed.
The ventilator (white) was incorrect for this version so, (not having a spare) I did what any red !https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcSo-tZfYdg-DIdVNBHiJkxlc90tYVDQBdVHs-qViusIFTVgu8lFprimered modeler would do… made my own.
More about the work on this turret later on.
Goofin’ around with the green putty.
The turret was specifically designed by Krupp for this vehicle. The ejecting port for spent shell casings was welded shut for the Porsche styled turret that was used on the production Tiger II. Dragon totally left this detail out (along with some other details I’ll be correcting later on).
Did some measuring and marking !http://t-static.de/smileys/misc/yawn.gifworked out a satisfactory result !http://www.kolobok.us/smiles/artists/laie/Laie_54.gifon that port.
Before I put that nice dark red primer finish on the hull with dollar tree paint, I slid a piece of aluminum foil in from the turret area beneath the grills and exhaust area…that way any overspray or washes will be contained since the foil will not turn to mush like tape or paper and will slide right out. I really like how the primer looks.
There’s some !http://www.evolutionm.net/forums/customavatars/avatar3345_1.gifvague engine details beneath those grills but I had no references to really put anything accurate
in there. So, just some general shapes, at least it’s not just an !http://www.picgifs.com/smileys/smileys-and-emoticons/bananas/smileys-bananas-077539.gifempty looking blank space.
For now you’re just seeing tinfoil under that screening.
Just basic stuff here…
The exhaust area has been !http://s3128.storage.proboards.com/5403128/i/45Dp1J7_I_ShX81733o4.giftaped shut.
Lots of hull detail under that thar primer.
- Flame cuts and texturing.
- Headlight conduits and conduit bracing.
- Handles added left & right for securing the rear hatch cover.
- Spare track hangers on the rear.
- Eh!http://www.bassboatcentral.com/smileys/sweating.gif, probably forgot some stuff, look it over.
The dragon kit (!http://forum.macworld.se/public/style_emoticons/default/elaktflin.gifagain) didn’t have the track bumpers beneath the sponsons so I had to cut some out from some leftover bogie wheels I had and “weld” them in place.
I modified the cable and tool fittings on both sides of the hull too. Got those headlights and fittings nice and even, maybe too even.
And yeah, I know what you’re thinking; that !http://emoticoner.com/files/emoticons/smileys/loosing-it-smiley.giftexture is too rough looking. Same for the turret.
But after several layers of paint it’ll even out just fine.
Here’s the view from the other side of the primer can lid.
Below:
That “stepped”
area inside the turret ring area is a compartment I added for some lead weight.
!https://tw.yimg.com/i/tw/blog/smiley/30.gifYeah I know, not necessary-but well, I even took the time to balance it.
So I can honestly say this going to be a well balanced !http://www.smilchat.net/smiley/astrologie/astro7.gifproject… eh?
And a view of whats going on back there
!http://www.thescifiworld.net/img/smilies/terminator/terminator010.gifand !http://www.freesmileyfaces.com/files/day-by-day/communicate-smiley-faces/74.gif(not sure when) with plenty more updates…
!http://www.millan.net/minimations/smileys/whew.gifnow, where did I put that SD card…!http://smileys.newbeginningsnetwork.com/piwigo/galleries/MOODS_AND_EMOTIONS/wondering_confused/pondering-and-thinking-smiley-emoticon.gif
Save
