Weathering - Post-Shading (RelentlesStorm)
It’s been a little while since our last update on tthe Panzer II “Paint Mule”. Because our efforts with it are largely experimental, I do need confidence of an uninterrupted block of time without the accompaniment of the fatigue of the work day and evening domesticities.
RelentlesStorm’s next step in our reference point is the post-shading of panel lines and recessed areas. Preshading a model with a multi-coloured camo scheme is kindof pointless, since the overlapping camo layers will nuke whatever tonal variation that your preshading would’ve otherwise provided a single-colour scheme. Instead, we can achieve the tonal variation on a multi-coloured camo scheme by post-shading. You’ll apply it whever you would’ve applied a preshade, only this time using a dark, neutral and translucent shade over the top of your camo scheme. Like preshading, this should be a subtle effect but a heavier application can kick off your weathering.
RelentlesStorm used AMMO Shader “Grime” A.MIG-0854, however this particular line is out of production, replaced with the funcitonally identical AMMO Matt Shader A.MIG-0737. The key difference is that this shader leaves a matt finish as opposed to the Satin finish of the previous line.
I’d sort of forgotten about this step as I was psyching myself up to do Workbench’s Oil Dot Filter, so when the rare opportunity to work on this vehicle arrived I didn’t have product on hand. To this end, we concocted something from Vallejo Game Colours comprising:
- 2 Parts Beasty Brown 72.043
- 1 Part Stonewall Grey 72.049
- 1 Part Black 72.051
- 8 Parts Glaze Medium 73.596
- 12 Parts Airbrush Thinner
- 8 Parts Airbrush Flow Improver
The Glaze Medium is the key here, as it allows the paint to be thinned to the point of translucency but provides sufficient binder to prevent a post-application separation of the pigment from the paint structure when thinned to this extent by other media.
This was a very wet mix that didn’t atomise particularly well through our 0.2mm airbrush. It went down with much less subtlety than RelentlesStorms targeted application of airbrush-ready premixed AMMO product, but had ultimately acheived the following effects for us:
- Recessed areas and panel joints have a darker and more weathered hue, simulating a buildup of grime and dust
- Heavier application of this shader than intended has actually mitigated the sense that our earlier oil colour filter was too subtle. Much of the starkness between our camouflague colours after the previous step is subdued
The effect is very noticeable against the port side of the vehicle, which has so far only recieved some light sponge chipping against the basecoats.
The product was allowed to cure overnight before clear-coating with Tamiya X-22.
