They look pretty darn good! You look almost done now, what’s left to go?
Thanks Gamera!
What’s left? Well, I have to put the decals on the U-3A, which I am going to do in a bit. I think then I might add a bit more lead to the glass areas, at least on some of them. Then I will spray Future on the T-29, keeping my fingers crossed, and spray then all with the Krylon matte. Guns will go on the AC-47, and perhaps the B-25. Dad says that the trainer he instructed out of was specifically designed for training, and wasn’t a retrofit bomber, so it didn’t have guns, but I think they would look cool, so I might add them anyway. Then I have to decide if I want to add antennas and a few other details. After that, it is wait on the plaques and glue it all together. So, as long as the plaques are made on time, I should make it by Christmas. [:D]
Hi !
I like all that you have done to this point .Now , that said you have experienced one reason why I don’t like any acrylic paint .It’s too translucent and I don’t like loading the model down with paint . I use the Regular M.M. enamels thinned fifty -fifty and use very good artist brushes to apply the paint .Coverage in one coat !
The wrinkling is something I have experienced only once .I used " Brand X " paint over the Rustoleum primer and it did exactly that . Plus , question .? Did you carefully wash the models before painting and between coats of the two paints . I would think a good wash with luke warm water and Dawn and rinsed very well would’ve helped .I do like the idea and the work to this point though .
UPDATE 18
Hi Everyone!
Duh!!! I forgot to say that I will add the props and paint the tips before I spray the Krylon.
I think I’m starting to agree with tankerbuilder, as far as regular MM versus acrylic MM. I really like the acrylic, as it goes on smooth and even, and cleans up with water, which doesn’t smell bad like mineral spirits or other paint removers needed to clean up enamel. Unfortunately, due to its opacity, it seems that you always have to put extra coats on.
I generally find that the enamels are kind of sticky, or tacky, when I use them. Thinning them fifty-fifty would probably eliminate this, allowing them to paint smoother. The odor, though, would not be eliminated. In my short modeling rebirth (we all modeled as kids, didn’t we?) I started with enamels and have been gradually changing to acryllics because they are easier to clean and do not elicit chewing out from the CiC.
On small models though, where the details are just 1000’ths of an inch, the thickness of the primer/paint layers can make a big difference. I think I could take a lot of heat for that perfect paint job (if there is such an animal).
As for washing the models, tankerbuilder, I did not wash them. I put them on their rods and sprayed the Rustoleum primer, which went on very nicely. I never touched them before I sprayed the Rustoleum paint. I’m pretty sure that, in my case, the wrinkling was because the garage was too cold for spraying.
Anyway guys, the decals are all applied, as I put them on the U-3A earlier today. Overall, it went pretty smooth. Even the U.S. Air Force decals on the wing tips went on nicely. The only real problem I had was the white stripe. First, it is so thin that I had difficult time cutting it straight and applying it. It took a few tries, and I was just about to give up when it suddenly worked. I know that it isn’t 100% correct, but I’m happy with it.
Here are all of the planes with their decals, dry fit to the base.
Some comments about the decaling process.
Cedarleaf did an excellent job printing the decals and the decal paper they use was easy to work with.
With decals this small, I departed from the prescribed method some. After cutting the decal, I would hold them between my thumb and forefinger, and hold them in warm water with a few drops of dishwashing soap. While holding the decal in the water, I would use my other hand to dip my utility knife in the water, and dab it on the model where I was going to be applying the decal. I then used the corner of a paper towel to suck most of the water back off of the surface. In the meantime I had removed the decal from the water and dabbed the water off of my fingers with a paper towel. The decals never left my hand until they were ready to be removed from the backing.
For the smaller decals, when I thought that the decal was ready to be removed from the backing, I would slide the flat side of the utility knife along the decal, so that the decal adhered, face down, to the knife blade. Not waiting long enough caused the demise of more than one decal. The next step, sliding the decal on the model was the tricky part. Most times it worked like a charm, but occasionally, the decal would wrap on itself. Sometimes I could get it unfolded. Sometimes I could not. This step spelled the demise for a few decals as well.
For the larger decals, when the backing was loose, I started it sliding while holding it between my thumb and forefinger. I would move it just far enough to grab the paper with tweezers, then I would hold it next to the model and use either my finger or the utility knife to hold the decal in place while pulling the paper out from under it with the tweezers. I had the same problem on a couple of the decals, with the decal wrapping on itself.
In all cases, once the decals were on the model I used the utility knife to very carefully move the decals in to position. Sometimes this meant dabbing a bit more water on the surface to allow it to slide better. Sometimes it meant sucking water off with a paper towel so the decal wouldn’t be surfing the wave. I tried to be careful and not put the knife on printed parts of the decal when moving it so as not to scratch the decal.
All in all, I would say it went somewhat better than I expected, but I sure am glad that I made duplicates.
CHEERS!!!
UPDATE 19
Good Morning All!
I didn’t get anything done on the display yesterday because my dad is in the hospital with big time constipation. He hadn’t gone in 2 weeks and nobody knew until he had to go to the emergency room. He is doing better and hopefully he will go home today.
I did take a few pictures of the T-29, which I had sprayed a coat of Future on. You were right Pawel. The Future did the trick. As you can see, there are still some issues with it, but after all it has been through, it doesn’t look bad.
On another note, I stopped by Sooner Trophy on the way home from the hospital, and the plaques will be ready Friday.
I’m not sure if I will have any time to work on the display today, but if I do, I am going to add the guns on the AC-47, and start adding propellers. I still haven’t decided if I want to add the guns to the B-25. Nor have I decided if I want to add the antennas on the AC-47, T-34, T-29 and U-3A. If I did it well, it would look really good, but there is also the possibility I could screw them up.
CHEERS!!!
Hi Again!
The following isn’t about my display, but it is related to it, and I thought you might find it interesting. When I got to mom and dad’s house yesterday, before going to the hospital, dad had left an old (April 2005) copy of the Air Force Magazine out for me to see. In the magazine was an article titled “20 seconds over Long Binh” by John T. Correll.
The article tells the heroic story of the events that earned A1C John Levitow the Medal of Honor. It was Feb. 24, 1969, and the second day of the Tet offensive. In response to rocket and mortar attacks, Spooky 71 (The plane shown in the paint scheme plans I used to paint my model), took off from Bien Hoa Air Base for a “combat air patrol circuit” over the Saigon/Tan Son Nhut area. Levitow was the loadmaster on Spooky 71 that fateful night. He was on his 180th combat mission, but had never flown with this crew before. He was filling in for a loadmaster who had taken his place when he was sick.
At about 11:30 PM, thirty minutes before being relieved by another gunship for the midnight-to-dawn shift, Spooky 71 was diverted to provide support to the Long Binh Army post that was under mortar attack. Seeing the source of the mortars, Spooky 71 flew to knock them out. In route, the unlucky gunship flew into the path of an 82mm mortar round, which struck the top of the right wing.
According to the article, the commander, Lt. Col. Robert A. Davidson said, “The resultant damage was a hole two feet in diameter through the wing and over 3,500 shrapnel holes riddling the fuselage… The occupants were helplessly slammed against the floor and fuselage like so many rag dolls.”
The navigator, Maj. William P. Platt said, “At that moment, a loud explosion was heard and a bright flash filled the aircraft. Even in the navigation compartment the flash lit up the inside of the aircraft like daylight. The aircraft veered slightly to the right and down.”
Levitow said, “I felt as if someone had taken a two-by-four and squarely hit me against the whole right-hand side of my body. All… of the enlisted got wounded and the officers did not. I think it was a very discriminatory flight.” Levitow and one of the gunners, Sgt, Ellis C. Owen, were in the process of dropping a flare when the mortar struck. According to Levitow, when they were hit, he Owen, Sgt. Thomas Baer, the other gunner and SSgt Edward Fuzie, the flight engineer were knocked to the floor and the flare was knocked out of his hands. Since his “finger was through the safety pin ring the safety pin was pulled.”
The flare was armed and rolling loose in the aircraft. At most there would be 20 seconds before it exploded. Levitow, who had 40 pieces of shrapnel in his leg between his knee and his hip, was dragging one of the crewmen to the center of the cabin he saw the flare between the No. 1 minigun and a jumble of spilled ammunition. Platt said, “Levitow was struggling toward the flare despite the violent maneuvering of the aircraft… Dense blue smoke was pouring out of the burning flare fuse.”
Had the flare ignited, it would quickly fill the aircraft with toxic smoke, incapacitating the entire crew. Levitow recalls, “I couldn’t walk. I crawled to the location of the flare. I had a real tough time grabbing hold of it with two hands because of the pain in my leg and everything. They tell me I ended up jumping on it, finally getting control and dragging myself and the flare back to the rear cargo door which was open and just managed to push it outside the door as it ejected and ignited simultaneously.”
The citation to accompany Levitow’s Medal of Honor put it this way: “Unable to grasp the rolling flare with his hands, he threw himself bodily upon the burning flare. Hugging the deadly device to his body, he dragged himself back to the rear of the aircraft and hurled the flare through the open cargo door. At that instant the flare separated and ignited in the air, but clear of the aircraft.”
Carpenter said that he “had the aircraft in a 30-degree bank and how Levitow ever managed to get the flare and throw it out, I’ll never know.” In the nomination package Carpenter added, “Levitow’s progress was clearly marked with his own blood on the f loor of the aircraft.
Spooky 71 limped back to base with Carpenter saying, “I consider the fact that the aircraft was able to fly at all a miracle.” Despite the fact that the gunship had a two foot hole in its wing, a flat right tire, and was leaking both aviation fuel and isopropyl alcohol, two highly flammable substances, Carpenter was able to bring her in safely, get her stopped and get the crew off the aircraft without further incident.
Levitow passed away November 8, 2000, at the young age of 55 following a lengthy battle with cancer. He willed his Medal of Honor to the Enlisted Heritage Hall at the Senior Noncommissioned Officer Academy at Maxell, AFB, Gunter Annex, Alabama. It is part of an award-winning display that includes a surplus C-47, with the color and markings that Spooky71 bore in February 1969, and a life like mannequin of Levitow inside, struggling to get the flare to the door.
As a bonus, dad attached a note dated 4/6/05 that reads:
“I saved this article because it describes and pictures what I did in Vietnam in 1966. Bien Hoa is where I first reported in Jauary. I was later assigned to Saigon/Tan Son Nhut, Binh Tuy and finally Danang where I was flying over the Ho Chi Minhtrail at night shooting at trucks.
I left in Oct. 66 because Janey was very ill and needed to be moved to a different climate. In January ’67 my crew was shot down and killed by a hit in the flare box mentioned in this article. The toxic fumes knocked out the pilot and co-pilot such that they crashed in level flight. (In this article the flare did not ignite inside the plane,)
I would have been rotating back to the States before then anyway, but most of the crew that I trained were still there and I hated to hear that – in fact, the load master was brand new on the last mission I flew – where we were involved in two hours of flare support for some marines who were surrounded by VC or NVN south of Da Nang. He got brought up to speed in a hurry.
I could go on and on with stories, but I won’t.”
CHEERS!!!
UPDATE 20
Greetings All!
The models are completed. I put the guns on the AC-47 and B-25 and then put the propellers on all of the planes. This was a bit more complicated than I thought it would be, because all of the posts broke off the propellers, except for on the T-29propellers. This made it somewhat difficult to get them aligned properly, but I did the best I could.
Here are the aircraft dry fit onto the base.
All that remains is to attach the plaques, pins and aircraft to the base. The plaques should be ready Friday.
And BTW, my dad is doing better and should go home tomorrow.
CHEERS!!!
Good Morning Guys!
Sooner Trophy didn’t get the plaques done Friday like they had promised, so I didn’t get to complete my dad’s display this weekend. They are supposed to be ready Monday.
Until then, here is a site you may be interested in. Click2Detail (AKA 3Delivered), the people that printed my planes, is Beta testing a site for selling models and accessories, and asked me if I wanted to post my planes, which I did.
click2detail.com/browse_products.php
What do you think?
UPDATE 21
Hi Everybody!
I picked up the plaques today from Sooner Trophy. I had to make a trip back to have them redo a typo and a slanted cut, but after that, I am happy with the way they turned out. I put them on the base, along with the U.S. Air Force insignia pins, using Loctite Gel Control Super Glue. I used an old drafting T-square to aid in aligning the plaques properly.
Although I only put one light coat of stain on the underside, and didn’t put any Polycrylic on it, I had a plaque made for it that contains a brief description of the display. I also added eight Waxman Soft Touch Bumpers to protect the furniture where it is displayed from getting scratched and to lift the base to protect the plaque.
The next, and final step, is to glue the planes on.
CHEERS!!!
UPDATE 22
Well Guys,
I finished the display with nary a day to spare. Our family is getting together in just over 12 hours to celebrate Christmas, and although it was close, I will be giving dad his display after we open gifts.
Here are several pictures of it. MERRY CHRISTMAS!
Wow, that’s just fantastic, the aircraft, the base, the whole darn thing!
Glad to hear your dad is feeling better and once again thanks for sharing with us.
And a big Merry Christmas to you and your family!
Hello!
Merry Christmas! Ain’t that a nice gift! What’s comin’ next? Would that be that AC-47?
Paweł
Thanks Gamera and Pawel!
What’s next? Good question. I have a few options.
There’s the AC-47, which I plan to strip with Oven Off (unless somebody has a better suggestion) as soon as I can get to the store and buy some. I think it may be a long process. In the meantime, I have a couple of other little projects.
First, I am told that Click2Detail has already sold two T-28s.
https://click2detail.com/products/BY/T-28-Trojan
The first thing I am going to do is make a more generic decal sheet to go with the aircraft, and not the personalized one that I used on my display.
After I finish the decals, I am going to finalize the 1:700 scale Thresher/Permit Class submarines I have posted on the Click2Detail site that should be available after the holidays.
Also, what got me into aircraft in the first place was being asked to make some 1:700 scale aircraft in exchange for printing parts for me. I made rough drafts of several ‘50’s era aircraft and sent them but the project has been somewhat on hold. I think I will detail the aircraft in 1:350 scale and add them to the C2D site as well.
The images below show the aircraft in their rough, undetailed state. Perhaps I will start a WIP of the detailing process?
Happy Holidays to all and thanks for your support!
UPDATE 23 – 12/25/2013
MERRY CHRISTMAS EVERYBODY!!!
With the model complete, the next step was to prepare it for delivery to dad. Thanks to Amazon, I just happened to have the perfectly sized box for the display. It only needed to survive a 20 minute drive to mom and dad’s house, so I didn’t need a top.
Bruno helped me wrap it.
Dad liked it and told me that he was really proud of it.
Mom said it was beautiful and said that I should sell them. She thinks that a lot of Air Force retirees would want one with the plane(s) they flew. She is probably right, but it cost me just over $300 to make it, not counting the time I put into it. I’m not sure how many people would want to pay $400 or more for one.
Anyway, my office/work shop is a lonely spot at the moment, with both Greenling and dad’s display gone to their new homes. That is the down side of making models for others. You spend a lot of time with them and then they are gone, leaving a vacuum in their wake. [:(]
I guess I’ll just have to fill it. [:)]
HAPPY HOLIDAYS!!!
Great piece
Thanks captfue!
I hadn’t thought about it in a while. I used to get to see it every week, but my parents moved to south Texas, so I don’t get to see it or them anymore. :o(
I never knew when I started this display that it would fuel a passion I have for making 3D printed models. I’ve made numerous models since then, and Click2Detail is now selling many of them. If you haven’t seen it already, my current project is a diorama I’m making for myself.
