1967 McLaren M6A Sunoco
This is a Fisher Model & Pattern resin kit from the mid '90s. The castings are quite nice. It also has white metal & aluminum parts and a nice sheet of photo-etch. I really like the note at the top of the very informative instructions: “This kit is not suitable for children or adults with bad attitudes.”
The parts are cast well but like many resin kits there are some pinholes to clean up in the body but they are not in difficult places to deal with and none are on the main surfaces.
I scribed the panel lines a bit deeper while I did the standard clean-up. Still a bit more work before it’s ready to paint.
Now that all the parts have been dry-fitted, a base coat of white primer was applied to the body…
The Sunoco Blue is a mix of Testors Dark Blue and Dark Red.
Even though the tires are resin they look great on the finished models. The wheels have cast white metal outer rims and on the other Fisher kits I’ve built they polish up fine and look great.
I noticed one of the fronts had a small defect where the mold didn’t fully fill that was too deep to polish out.
I soldered it up, filed it smooth and repolished it.
You soldered into the gap of the white metal casting?! It actually stuck?! I’ve tried that before and failed miserably…what is your process?
It looks great after sanding and polishing.
The gap has to be clean, sometimes it has to be made a little bigger to get a good solder joint. (I cleaned this one out with a knife.) Use lower temperature solder to lessen the risk of melting the part and use soldering paste.
When I polished the rear rims I noticed they had some irregularities due to shrinkage during casting that also could not be sanded/polished out. I was so focused on the issue in the front wheel I missed that the other front also had similar shrinkage issues as the rears.
Machining the surface to smooth it out is an option, but with white metal being so soft it is risky to clamp in a chuck tight enough to hold it and not deform it. So I machined a new set from aluminum. The kit supplied parts are next to the tires. They probably would have looked OK, but I know it would have bothered me.
These are the assembled wheels with the aluminum outer rims.
Really nice work making the new rims. They look good in the tires.
This is the photo-etch sheet.
This is one piece of PE folded up origami style for the tub. It’s engineered very well.
The seat belts were done with tape and the supplied PE hardware.
Last night, and after the Testors enamel cured for a while, I color sanded it and then shot the last color tint coat of TS-72 Clear Blue. It is not recommended and it can be very risky applying lacquer over enamels, but I have done this process with these paints enough to do it safely, and in 24 hours it’s even safe to handle. Now it has that “electric” quality the real car has.
Thats a really nice looking resin body. Made me look them up and wow, pricey. I can see why though. your “electric blue” paint is looking great. Looking forward to seeing this one built up.
I would have thought the Tamiya lacquer would have been too hot for the Testors enamel. You were quite lucky. It turned out great!!
Not lucky, experienced.
The intake stacks were painted with FusionFirm Chrome and LP-65 Rubber Black. The hose clamps are decals.
Wow those intakes look great, that chrome is very sharp.
The mirrors are white metal and would polish up nicely, but I wanted them pinned for a stronger attachment to the car and the pylons are very thin; the same thickness as the pins I used. So after cleaning up the pylons the mirrors were painted with Alsa Chrome and Mylar discs were added for the faces.
I have just recently discovered FusionFirm. Its great stuff for the price!
The dash is two very thin pieces of photo-etch. The gauges printed on the instructions were to be cut out and sandwiched between the two metal pieces. I made new gauge decals instead.
I was very relieved when the first decal went on with no problems. (The kit includes two sheets due to them being delicate; a nice touch.)
I took my time putting one or two decals on each evening. They were prone to silvering so I made sure each one was clean before adding another.
It turns out the second sheet was needed for a couple elements. They are all on it now.
Looks great. From the photos you really nailed those fender decals. I always have trouble with those.
