1966 Aurora Wanderer Whaler
Looking to learn some more information in the use of the mast rings and WHEN did ships use the ratline BARS vs. rope for the shrouds.
Working on the cathead assembly, man back in the day, kids had it rough. The cathead does not come with any guide pin hole so they wanted kid to hold the parts together while the glue dried, (they never had acc glue) back in the day, can you imagine kids sitting still long enough to let plastic model cement set up…
I drilled out a few holes and used acc to fix the parts together I’ll be careful when I setup the bowsprit rigging. I’ll repaint and weather before setting in place.
Great to see such an old kit getting this level of attention - I never saw this kit back in the day, its amazing how much detail it has for the time.
A trick for getting the best scale finish on wood parts I picked up building wooden model railway cars is to coat the wood you’re going to use before building the model or part, whatever, with a sandable acrylic clear coat (I use interior grade Minwax for furniture) and brush it into the wood, which creates a penetrating sealer on the wood. Let it dry and sand it with fine grain sand paper then rub down w steel wool to remove saw marks and any fuzz. The result is a smooth surface that paints well, looks more “scale” but still has evidence of the grain. For stained wood start with a dip in diluted stain, let it dry, then paint it with the acrylic and sand it. The result will look distressed, so a wipe with a second layer of stain will even that out if that’s the look you’re going for.
Konrad
Hey, I’m cruising the ship section of the forum today, and this caught my attention. I’m curious.
That copper hull looks fantastic. I know virtually nothing about ships, so seeing that immediately made me wonder—did the real Wanderer actually have a copper-plated hull?
I did a little digging, and apparently it did! I had no idea wooden ships were actually covered below the waterline with sheets of copper to protect the hull from marine growth and wood-boring organisms. That’s fascinating.
So now I’m curious about how you reproduced it on the model. Is that actually some kind of metallic foil or tape applied to the hull, or is it a paint technique? Whatever you did, it really has the look of individual copper plates.
And nice work on that little crank handle too. That’s a tiny detail, but it looks much better than something that small has any right to. :grin:
The USS Constitution comes to mind when discussing copper clad hulls. Paul Revere provided the copper cladding.
I airbrushed on a coat of Floquil Copper, I still have to do my corrosion treatment, it will look similar to this photo. Floquil copper, with Floquil light green and Antique white, washed down with Turpentine.
Okay, now you’ve really got my attention. I assumed there was some kind of foil or individual plating involved—I didn’t realize that was simply airbrushed copper paint.
And Floquil! That name sounds very familiar from my earlier modeling days, although I can’t remember if I ever actually used it.
Now you’re going to add the green corrosion on top of the copper. I’m definitely going to follow along with this. I’ve spent my entire adult modeling career worrying about aircraft weathering, and apparently there’s a whole other world of ways to make ships look old and abused that I know absolutely nothing about. :joy:
Thanks for explaining it!
Here is how I do it. Use the old Floquil Paint, but am looking to experiment with enamels - I’m not sure this will work with water base.
The lower hull painting /Corrosion detail was done in the following manner: You must use FLOQUIL Brand Paints for this step.
  1. Coat the hull with Floquil Copper (ONLY this brand of paint will work), let dry 24 hours.
  2. Using a #2 size brush, use Floquil Lt. Green, streak the hull in from the top of the plates to the keel in downwards strokes only. NO BACK AND FORTH BRUSH MOVEMENTS, IT WILL BLEND THE COLORS.
  3. Using a #2 size brush, paint Floquil Ant. White directly over the Lt. Green, and then while the paint is still damp wash the paint down with ONLY turpentine, any other solvent is too strong. Let dry overnight, the smell is not that bad, but if you work indoors on your models you will want to do this outside and let dry there.
Now that’s the kind of explanation I was hoping for. Thanks for taking the time to spell out the whole process.
What’s really interesting to me is that you’re not just painting green corrosion onto the copper. You’re actually building up the light green and antique white and then using the turpentine to pull everything downward and create the streaking. I never would have thought of doing it that way.
This is exactly why I’ve started wandering into parts of the forum outside of aircraft. There are all kinds of techniques you guys are using that I’ve simply never been exposed to.
I’m actually planning an F-117 build where I’m looking for some unusual ways to create the layered, weathered appearance of the modern aircraft. Obviously I won’t be weathering copper, but what you’re doing here has me thinking about whether I can borrow some of the same ideas—building up different layers and then manipulating them rather than simply painting the weathering on.
I’ll be really interested to see if you can duplicate the effect with currently available enamels, because it sounds like that old Floquil paint is becoming a pretty precious commodity.
I learned the technique from a booklet called How to build Plastic Ship Models. They have several booklets on eBay for sale. The booklet is out of publication.
Sam, Check your inbox, I sent you a link
Got it, thank very much!
The Tryworks.
From the past week or so I did a deep dive into the tryworks on a few whalers. All whalers had them to render and melt the oil from the fat. Sometimes the tryworks were built enroute to the whaling grounds, some were left built. There are a few photos surviving from the Wanderer that show the tryworks. The model has the tryworks a bit plain, above the 2 kettles was a removable cover/roof section which 2 vent stacks were used to vent the heat and smoke up and away from the workers. The vent traveled through the upper cover as well.
What I wanted to replicate was these vent stacks to give the try works a bit more detail. I cut away the first covers vent bumps and sanded smooth, then cut an appropriately sized square tubing from my plastic stock and carefully cut away and resized the holes so that the square tubing would fit with a little play. I still need to cut and removed the upper roof sections where the stacks go through.
Because you can see into the tryworks, I had to create a “stop-base” for the stacks so you would not see them from the doors on the front and this gave me a base to also glue on as well. I wish I could have created and shown the kettles, but it was just too much in such a small area.
Finally got the base painting completed for the Aurora Wanderer Whaler, with this model I’ll need to step the deck in, THEN glue the halves together because of the deep contour of the bulwarks. no way to fit in place after the hull is together. So I’ll need to be a bit careful once assembled, she is going to be heavily weathered so a little wash hides a lot.
I really like what you’ve done with the copper plating. It looks like there are all kinds of variations in the color, even though I think you painted it all the same copper. I’m assuming that’s just the metallic finish catching the light differently across all those individual plates. It gives the hull a lot of visual interest.
I’m also discovering how much I don’t know about building ships. :joy: I had to look up what a bulwark was just to understand what you were describing.
As somebody who has never built a ship, the whole construction sequence seems complicated to me. I’m used to thinking in terms of fuselage halves, wings and cockpits. Watching you work through when the deck has to go in, what has to be painted first and what you’ll still be able to reach afterward is a completely different kind of modeling.
I’m learning a lot just following along.
Thanks, so far all I have done on the hull is paint it with copper, before I put the halves together and the deck in, I’ need to weather in inner bulwarks with a grime base, I’ll do this first so as not to put any extra dark wash on the main deck. I’m going to need to wait to ‘antique/corrode’ it. That because once I glue it together, I’ll need to address the keel, bow and stern seam when the halves meet. This will be some light sanding and filing to make sure the copper plates are uniform when you can see them.
Once that is done, I’ll mount it to the stand, them start installing the deck fittings.
Got the bulwarks grimed in and the lower hull glued and drying. Once I place the deck in, I’ll glue the bow and stern closed, but I need to leave it loose to fit the deck and the contour of the hull will not let you fit the deck if you glue the hull filly together.
That is looking great
Getting there, just slowly, the hardest part with be attempting to balance the weathering with the grime from the tryworks smoke. All ships were painted fairly good, but during the voyage, got really dirty from the smoke and oil residue from the blubber rendering. While the men generally kept the ship as clean as possible, the grime builds up over the long voyages.
I must have 5 pounds of clamping pressure on the bow stem in order to get it set right. I’ve used testors tube cement followed by liquid cement to enforce the glue into the voids. For the deck I use a small gauge needle to carefully put glue along the seam where the deck meets the hull. This will dry for 48 hours before I remove the clamps and rubber bands. The stern met together nicely, I won’t have much work to hide the seam.
