1/72 EKA-3B Skywarrior/Whale - DONE! 09/20/2015
Hello!
Today I started detailing the gear bays. I used styrene sheet and thin copper wire. Here’s how it looks so far:
Thanks for reading and have a nice day
Paweł
Wow! Great job, Powel! I really like the way the detailing is going in the gear bays. I’ll be watching your progress with interest as I plan to build the Air Force version someday.
Cheers,
Russ
Hello!
Russ - thanks a lot for your comment and for your kind words. I plan to build the EB-66 some day too, but there are so many differences! Then again you know way more about the ECM systems - I’m counting on your help here!
Tomorrow I have to go back to work, so to use the break I worked on some details of my models. I moved on with the gear bays - let me show you my favourite before-after shot. Here’s the gear bay OOB:
After I tuned it a bit:
I also added a small fuel vent on the horizontal stabilizer, correct for my BuNo, and deleted the large one (kit part E39, on the left side of the fuselage tail):
I also added the roller for the tail skid, that was missing from the kit:
The last thing I managed to do was to add the refuelling drogue (sculpted from Milliput):
Now I’m working to put everything together to paint the underside of the model white. Hope you liked the photos, thanks for reading and have a nice day
Paweł
Very nice work there in 1/72 on a very cool aircraft!
Hello Mike!
Thanks a lot for your kind words! I also think this machine is cool!
Have a nice day
Paweł
Hello everybody!
I wanted to close up the cockpit, but I realized I’m missing the insides of the so-called dittching hatch - a hatch on top of the Whale cockpit meant to be used to get out of the airplane when the normal way (the hatchway in the belly) couldn’t be used - like when landing wheels up or in the water. I read that this hatch was supposed to be open during the carrier takeoff by Navy regulations.
I have only very few references of how this thing should look like. But using what little I had here’s what I scratch-built using some styrene sheet, yoghurt can lid (aluminium foil) and some copper sheet and wire on paper backing:
I scribed all of those soundproofing seams, then went on to paint that thing:
After that was doneI glued it inside the canopy:
Now I can finally close that cockpit up and start some serious painting.
Thanks for looking and have a nice day
Paweł
Hello everybody!
Aftera long time I’ve got a small update. I put some of my trusty Tamiya primer on the model. It still works better with a grey undercoat:
There are two small antennae in front of the triangular opening that will take the tail skid. I’ve built those little antennae out of thick copper wire that I’ve flattened with a hammer and then filed to shape and then anchored them in appropriately shaped holes. This is almost more writing than actual work, but it gives me hope to keep them babies from breaking off before getting done.
Before I put the primer on I also glued the canopy on and masked it with thin strips of Tamiya tape and Maskol. Then I sprayed a coat of black to gife the frames their inside colour. On top of the black you can now see some overspray from the subsequent painting. The rear edge of the canoy had to be filled and sanded a little, the seam there was a bit too much for me:
That would be it for now - hope you like it! Thanks for reading and have a nice day
Paweł
[Y]Awesome work there Pawel! I’ve been looking at these kits in the various versions. I had never really looked at this aircraft much, until I visited the USS Midway Museum in San Diego last year and got a good look at the Whale they have on the flight deck. Its amazing that such a large aircraft could land and be launched from a carrier. Keep up the great work, I’ll be watching this build as well.
jelliott523 - thanks a lot for your kind words! Yeah, the Whale is really something special, isn’t it? Thanks for your comment and have a nice day!
Paweł
Hello everybody!
Today I finished painting the engines:
The undersides were painted Tamiya white primer, upper surfaces are Humbrol 129 over Humbrol 140 preshading. The red warning stripe is Humbrol 19. The rear of the fairing is a transition between Stainless and Iron from Mr Metal Color, Gunze paints. I picked up some panel lines with a pencil.
Now I’m going to install the engines - painting them after installation would be much harder. Also, there’s some filling required where the leading edge of the wing meets the engine pylon.
Paweł
My honest opinion is that you’re doing another one of your very detailed and fun to follow builds. I really enjoy seeing how you add so much to the basic kit. Thanks for keeping us up to date!
Looking good, Pawel! Keep at it!
Looks great Pawel.
Hello!
Sorry for my late reply!
Mike - thanks a lot for your kind words! I’m glad you like my work.
Devil Dawg, John - thanks a lot!
And i’ve got another Whale update for you - I managed to put some paint on my model. Here’s what it looks like now:
The stripes are for the paint scheme of the VAQ-131. I decided to paint them on instead of using decals from the Hasegawa kit, and I’ll be modifying the kit markings anyhow. The stripes and the anti-glare panels are Humbrol 33 black, and the antennae fairings are Humbrol 32 dark gray.
I also have painted with the paints mentioned above - preshading is Humbrol 129 gray over Humbrol 140 gray. White is Tamiya primer from a spray can.
I also found a useful trick on my way - if you’re painting over a layer that had a lot of time to dry (like one week here) and there are some imperfections (like places where the tape lifted a bit) you can wait till the fresh layer is dry to the touch, and then clean the imperfections up with a Q-tip moistened with airbrush thinner - it worked for me here.
I hope you like it - thanks for reading and have a nice day
Paweł
Looking good!
Wow! I’m very impressed! I just got back from the U.S.S. Lexington and they have on sitting on the flight deck just as you emerge on top. God, that’s a big bird!. My daughter’s Navy Jr. ROTC instructor actually flew one, so I am very interested in this thread. I’m trying to get a picture of him with his plane so I can build it.
I noticed the one on the Lex had a bubble canopy and that yours does not. I guess that changed depending on the model? Anyway, great job, especially on a 1/72!!! Keep up the great work. Raymond
Mike - thanks a lot!
Raymond - thanks for your kind words! When you get that picture, could you post it here? It would also help if you asked the man about VAQ-131 - that’s the unit “my” Whale belonged to, I could use every help here. BTW, I plan to model the BuNo 142403.
As for the canopy - it changed between models, but only minor details. Looking from the deck it seems to be bubble canopy, but on top there’s rather large “roof” with the ditching hatch in it - much better noticeable when you’re handling a model. So no real difference between my model and the Lexington whale - in fact they are pretty close together. The Lexington whale looks like a KA-3B tanker to me.
Thanks for your comments and have a nice day
Paweł
Hello!
Another update - this time I tested how a wash could be applied to my model. I chose the horizontal stabilizers as the test ground. I lightly thinned some Humbrol 32 with turpentine and applied this mix to the panel lines over a thin layer of future. Before an hour passed, I began to wipe the was down with a dry paper towel. The results were OK - as the photo shows:
Paweł
[Y]She’s looking great Pawel!!! Can’t wait to see this beauty finished!
jelliott523 - Thanks a lot! I can’t wait too - but it’s going to take some time. I’m waiting for some custom PE and decals to arrive.
In the meantime I’m working on the landing gear - I added some Eduard PE and thin copper wire for now:
Paweł
