1/48 Airfix Hurricane Mk. I 501 Squadron (Ken Mackenzie) FINISHED
Hello folks,
I figured I’d share may latest project. It’s been quite awhile since I’ve done a Battle of Britain subject. I decided to have another go at the new tooled Airfix Hurricane Mk. I.
I’d be hard pressed to find a more interesting subject than the cover art machine, so I figured I’d chose this option. It’s 501 Squadron Ken Mackenzie’s Hurricane, serial number V6799. On October 7th, 1940, Mackenzie ran out of ammunition so he used his wingtip to knock the tail plane off a Bf 109 sending it plummeting. He then managed to land the stricken Hurricane with a damaged wing, earning the nickname “Super Mack”. Mackenzie would score 11.5 before being shot down and POW’ed himself in 1941. I read that he spent most of his time trying to escape and even managed to convince his captors that he was crazy, so he was released on 1944!.
As I said, I built this one when it first came out. The only thing I remember was that it’s better than the Hasegawa kit, which I also built years ago. I started with the pit, which is quite nice. My formula for RAF cockpits consists of XF-71 Cockpit Green with a few drops of XF-19 Sky Grey added so it leans more into the grey area. I added some Eduard belts from the stash.
Airscale decals take care of the instruments.
Wing spars ensure proper positioning of the cockpit to the lower wing. It’s also integrated in with the landing gear bay.
I had this together in no time. The fit was great.
I deflected the control surfaces. I always do this when I can.
In general, I hate RAF roundel decals. They’re big, clumsy and I find then dfficult to snuggle down. I decided a long time ago it’s easier to paint them on. I figured I’d use Montex for these then the kit decals for the fuselage codes and such. I was fortunate to discover that Montex offers this exact subject, so I jumped on them. When they arrived, I spent several hours painting and masking. It was tedious but worth it.
The fuselage was sprayed XF-19 Sky Grey before I added the SD-X masks.
Once I had all the markings painted in and taped off, I started on the underside “Sky Type S”, or whatever they called it (It’s my understanding there’s a duck egg bluish color too, but I prefer this color better). My “recipe” for this consists of XF-21 Sky, with a few drops of XF-7 Flat Yellow, and a few drops of XF-19 Sky Grey. I then added some white for fading and streaking. After it was all said and done it looks like this. I will weather it heavily with a postshade later.
I ran out of time. I’ll go topside on this turkey soon.
Watching this one
Yep stencils although labor intensive look way better than decals. Thanks for all the tips. She’s gonna be another masterpiece!
Another great build in progress I see, another lesson from the master builder himself!
Thanks guys, nice to have you along.
hardly…but thank you nonetheless.
I’m in for sure. Although, looks like you’re more than halfway there!
I always enjoy watching your works in progress. So edifying, such superlative skills on display. BUT, you work rather quickly so, to paraphrase a line from “The Usual Suspects”, And like that… it’s gone. Therefore I’m glad I found this one before it disappeared around the corner.
Looks great so far. Also good to see Airfix putting out some nice kits.
Thanks guys.
Ole, Airfix has been putting out some gems lately. You should see their P-40B and P-51D, both awesome. My one gripe is the color and texture of their plastic. It’s a bit soft and I prefer the normal darker grey.
Anyways, I’m clicking along on this one. After adding Montex masks, I got to painting the standard day fighter scheme. I started by using up the last of my Gunze Dark Earth. From now on I’ll mix this color with Tamiya paints as I don’t particularly like the glossy nature of this paint. I added XF-57 Buff and faded it a bit.
I prefer slightly feathered pattern lines, so I used blue tack roles for the camo pattern. It was time consuming but well worth it.
I used XF-81 RAF Dark Green then sprayed the green. I faded this with the XF-57 as well. I then removed all the masks. The Montex worked very well.
I added some exhaust staining and general westhering around the engine area with a postshade. XF-19 Sky Grey was used for the heat staining behind the exhausts. I was going for subtle.
Mackenzie used this machine to ram a BF109 and that endeavor ripped off the starboard wingtip. I figured the RAF fixed the damage and put it back on the front line. I decided to simulate this repair with fresh Dark Green paint. I figure it will blend in a bit more when washed and weathered a bit.
I dirtied up the bottom too, concentrating on the center line.
Almost time for a gloss coat.
Awesome work!
I do have a question. What’s the story with the ramming? It would be hard to ram a 109 with a Hurricane. Was the 109 chasing someone else? Was the 109 already damaged? Was it an unintentional ramming?
The fresh green paint is an awesome and interesting detail.
Beautiful work, Joe. The Spitfire has been given credit for winning the war for Britian, but the stats show the Hurricane actually did far more for the effort, it just wasn’t the darling. Too bad, its a beautiful bird and your version looks likes its in motion.
BK
Beautiful work and your attention to details is second to none!
Now I have go go spend money on Airfix kits!
5 days. I’d still be screwing with the cockpit.
Looking good as always, Joe. I’ve always wanted more info about how you mask and spray your roundels, so happy you showed the process, thanks.
I want to build my first airfix kit even more now.
[Y]
…and he says I build fast? [^o)]
Man, if I built at your pace, I would have my stash cleared up in no time! To top it off, the plane looks fantastic!
Lovely work Joe. Next I’ll be waiting for you to dispense with the stencils and just use your airbrushing skill to paint them on
Thanks for the compliment. It was totally intentional. This link discusses the encounter pretty well.
https://www.telegraph.co.uk/news/obituaries/military-obituaries/air-force-obituaries/5507963/Wing-Commander-Ken-Mackenzie.html
Thanks for all the kind words all. Have a great Thanksgiving.
Awesome work. Glad to see you are still turning out your masterpieces.
