Hi All,
I noticed a fondness of the BF 109 in this forum built in all types of scale and thought I’d share one Group Build that I did with an Airfix 1/24 scale. This WIP has already been completed so basically you’d see the process from the box up till the final completion. Thought I’d just do a OOB build but it got out of hand as usual. The color scheme and markings might not be that accurate as 1/24 decals are hard to come by here and I didn’t want to Helmut Wicks 109.
So… trying out. Looks like the number of parts are like 1/72 except larger. An OOB build could possibly be done but the scale calls for some detailing.
This is the box art
Just putting the engine together. To save time may not paint it or just flat black.
Not bad for an old kit…boleh tahan(in Bahsa Malaysia).
I was going for stock standard for this one to meet deadline. Perhaps new seatbelts and flaps down.
I wanted to see how far my painting skills could go for this. I see a lot of filling and sanding ahead and that will take up much of the time.
All the inerds will be patched quickly like the engine which took me only 15 minutes…anything that’s not seen when closed up gets minimal attention.
Sprayed all the interior and got all the individual components sanded and assembled. the part that’s going to take time now is the wheel well…it’s all see through. I’ll have to fair it up with side-walls for the GB. Won’t be super detailed…I’m going for painting to bring this kit up. And that was what I thought at the time.
Some little progress shots…seriously I’m going oob so I said…
The other night I was fiddling with my BF109 when I got called out for tea tarik(Local tea break).
I had just fabricated the leather cussion found on some 109’s seats and brought it out for the guys to see while the bondite was curing.
I used cello tape to mask off the seat so the bondite won’t stick onto it. After it hardened , I just popped it out.
The engine got a bit of painting done with black airbrushed on. I might just give it a wash to dirty it a little. Remember…it’s oob.
I thought this was going to slow me down I managed to find a solution to get the measurements for the wheel well walls by using plasticine.
The last two shots are just some of the odd bits that needed a coat of black.
I picked out the dials in black on the control dash board.
Everything looks flat now but with a little wash and dry brushing, the details will hopefully come up.
Continued in the next post…
