So I picked up from Age of Plastic on Shapeways his Tantive and two pack of Falcon’s. Thanks to Shapeways, they actually sent me three Falcons and then the Mouse slammed his fist down and the Falcons got removed from the site. I think mine were the last to make it out alive.
The Tantive is a marvel of miniature 3D printed engineering being design to be lit. And that’s what I did. Each engine tube is hollow to accept 1mm fiber. The main body of the ship is also hollow to run a 1mm fiber up to the open cockpit window. To light this little beastie I solder up two Pico LEDs and glued them back to back. The forward facing LED would light the fiber for the cockpit and the rear facing would light the 11 fibers for the engines. Each of these fibers were mushroomed and then pushed into the engines. I gave the rear LED a few coats of Tamiya clear Yellow.
This will be mounted on the base with the Zvezda giving chase. In the pictures below you can see how tiny the Tantive is.
An early lighting test of the cockpit and engines.
After some light blocking and primer coats.
And yes, the tiny, tiny Falcon is being lit as well. I drilled a groove in the bottom hull to accept a Pico LED. This was epoxied in place. Its hard to get good pictures of this as it’s so dang tiny!!!
A coat of black and then grey primer followed up by Tamiya AS-20.
I sanded the engine panel after final paint to reveal the semi transparent print material. I also did the same for the cockpit. And of course, the camera couldn’t focus well and over exposed the light. It’s not that bright in person. I’ll try and get some better pics today.
And all lit up!
