Ok finally some more progress, battery supplies hopefully sorted. Assuming I did this right I’ll be powering this with ~12v ~2.2A, with a battery pack of 3 18650 cells, and if I attach it all up correctly hopefully it won’t burn down my apartment!
So this showing the separate battery cell holders, spaced individually instead of all together to allow everything to fit.
the Battery Management System, this makes sure the battery drain is kept even and handles the logic to properly recharge them as well.
Little on board voltage meter, press the button and it will show the battery voltage, to see when it needs charging.
component placement
and after mounting and wiring up for good:
The Bluetooth controller lives!
Test rig for the bluetooth controller,
wired up for real
It talks to this program (test app on my MacBook that will then get ported to iOS for usage on iphone):
And when the two are connected the controller outputs this on windows (when the arduino is connected via USB):
Arduino pro mini mount:
Not done yet, just have the power/gnd leads in place
Audio board to place sounds and imperial march
That’s all done now, it will be connected to above arduino board.
There’s one other little component, there’s a special blue LED that drives 5-6 fiber optic cables in the top front area, that will blink when the Bluetooth control is not paired with the app, and then go solid when a connection is succesfully made.
All the programming is basically done, it’s basically down mounting up the electronics and praying that I solder things correctly. Hopefully a couple more weeks and this thing will finally be done.
