I couldn’t wait any longer! So! Here we go!
All the time I am building the interior I have in my mind that the exterior parts that I will be using are clear, but have a kind of frosting on them which lessens the detail that can be seen.
This in turn made me think very much about all the detail on the engines and in a lot of respects turned my hand away from the manual paint colours and towards much brighter and stronger metals, while the support structure remained the original colour used on these aircraft from mid 1943 onwards… and that took some finding and very much to my surprise of Afrika Korps origins!
The first things were to put the base engine parts together and have a dry fit just to give me an overall impression of what is going to be seen and what isn’t.
Next we split them down for painting
Believe it for not, over those two base engines there are 22 parts!
So, this is how the parts look after painting.
The colours are:
Cylinder blocks: AK Xtreme Metal stainless steel
Push rods and mounts AK Xtreme Metal Steel. What would the be the moving parts of the push rods painted with Vallejo Model Air Metal Black
Prop reduction gear, not yet painted.
Radiator - AK Xtreme Metal Copper
Air intake cylinder feeds AK Xtreme Colour Titanium. This just takes the colour variance away a little bit from the stainless steel cylinder blocks.
Here they are together. I recommend that you take your time in getting them lined up properly or you will not get them sitting correctly on the mount. Dry fit as much as possible. The colours don’t show up as properly as I would like as the weather here is dark and cloudy and I am having to photograph in artificial light instead of natural daylight. You can still see the tonal variances between the colours used that keeps the eye moving over the detail.
I moved on to the propellers and prepared to paint the insides of the parts and on a dry fit saw that there was no need to get the aluninium out and so just primed and painted the lot with Vallejo Model Air IJN Medium Brown 71.418 which is the corect brown for props for both IJN/IJAAF. You can only get this when you buy their IJN set. I also suspect that the IJAAF colour dark beige 71.416 only available in their IJAAF set is nearly the same colour. Still, both sets are worth getting as they will cover most if not all painting options for Japanese aircraft. The only thing to add is the warning ID colour which comes on the decal set, but can be painted on.
I decided to paint the exhaust pipes Vallejo Metal Colour Burnt Iron rather than start messing about with the manuals mixing colours and painted the engine support structure what will be the interior colour which after much research and going through my copious notes proved to be Vallejo Model Air 71.116 RAL 7008. This is actually an Afrika Corps colour and matches the interior of the Nick with only a 2% variance from the original Japanese chipset colour. this isn’t recognisable by our eyes at all!!!
The Prop reduction gear part was primed and painted along with detail painting the radiator. The radiator mounts which also mount part of the cowling were painted in RAL 7008 while the actual reduction gear case was painted in Vallejo 71.054 RAL 7024 which is exactly the right colour for the case but is not listed in the manual.
The auxillary gear that fits in the rear of the engine mount was painted with Vallejo 71.326 which is the correct colour with the rubber sleves being Vallejo 71.315 Tyre Black which is a good colour to simulate rubber. Air tintakes that sit on top of this were painted with AK Xtreme Metal Polished aluminium on a matt grey primer.
I have also built the 20 mm dual mount and that’s been painted Vallejo Metal Colour Magnesium
While the rear gunner’s spent cartridge bing gets the AK Xtreme Metal polished Aluminium, again on a matt grey primer
Next up is the main spar and beginning of the cockpit.
Questions and comments welcome
