I have started another project. This one is going to be a Ukrainian YPR-765A1 PRI .50 APC. The Netherlands provided a bunch of these APCs to Ukraine. The version I am building is the APC with an M113-style cupola in place of the 25mm turret.
I am starting with the AFV Club YPR-765A1 PRI SFOR model (35119). It is a later version from the mid-2000s with added mesh storage racks on the sides, Diehl tracks, and a few other new features.
I started by flipping over and cutting the kit ring to mount the 25mm turret to fit into the opening flush with the roof. I then cut the inner opening a little bigger (out to the keyed slots) to accept the M113 cupola.
IMG_20231203_204244173_HDR1920×1440 201 KB
IMG_20231203_2042534141920×1440 167 KB
I will also be adding a full crew compartment interior on it. To start, I added details to the lower hull interior by adding the front walls for the fuel tanks from sheet styrene.
IMG_20231203_2009572451920×1440 104 KB
I also detailed the inside of the upper hull by adding a layer of Kevlar with cutouts for the firing ports, handles to open/close them, vision blocks for the rear gun ports, and periscopes for the driver and commander.
IMG_20231203_2010104221920×1440 156 KB
I also added details to the inner surface of the roof hatch.
IMG_20231203_2010280461920×1440 160 KB
Lastly, I will be using a left over Academy M113 gunner’s cupola, armored surround, and gunshield.
IMG_20231203_2011080841920×1440 156 KB
This is how it looks so far. Pretty close to the Ukrainian one above.
IMG_20231203_2012108351920×1440 129 KB
More to came as I start on the interior using an Academy M113A2 interior. It will eventually look something like this on the inside.
YPR PRI 50 APC 1750×498 130 KB
More to come later.
