One of the other problems discovered with operating floatplanes during the early 40’s is that, compared to ships, planes are very fragile things.
Also, while a floatplane does allow you to land the aircraft anywhere there is water, the state of that water matters. In sea states that barely affected a cruiser or BB, you could not land a floatplane (which is makes for a bad day for the aviator in those days before aerial refueling and on bingo fuel).
If the sea is not too rough, then you get into the complexities of things as light as a Duck, Kingfisher, or Seahawk and those with the mass of a battlewagon. It’s actually some difficult to get a largge combatant ship truly dead-in-the-water. Ship handlers want “way” on, just so the ship will respond to control inputs.
It’s not always convenient to put a couple of MWB over the side to warp the a/c up alongside, too (which, by doctrine, was the best a/c recovery method). Even so, whaleboats and launches needed significant padding so as to not damage the floatplane, too. Which is fussy work, especially in winter, and doubly so as the latitude gets higher than 45º North, or South.
So, some whacky alternatives were tried. Only one with much success was a net bent to a spar, streamed from an after boat boom. The putative aviator taxied his a/c up until it washed up on the net. Then, the net was heaved around until the crane could collect it.
Which worked, except it often wrecked the rudder on the float. Or if a wing float was not holed or damaged in the process. It was also far too easy to drive the a/c up over the spar on the net, and that never worked out well.
But, what really put the floatplanes into storage was that an SBD with 1115 mile range at 185mph was a much better scout than an OS2U with only 805 miles at 117mph. Flying them off before a battle probably smart for not having them exposed (and full of flammables) to anything which gets shot at you. That, and writing up the damage report for flash-burning all the fabric surfaces off would not be good for anyone’s career, either.
