Worth the extra cost?
I have always used Italari kits for my trucks (and have been very satisfied with them) but I notice that there is a also a corresponding Revell kit for every single one. However, they are always 15 -20% dearer. My question is - is Revell 15 -20% better value/quality or should I stick with Italari?
If you like something I would recommend sticking with it if money is a major concern…However how will you know if you don’t try it. Buy a Revell of something you’ve already built in an Italeri kit and build it to compare the two, that after all is really the only way you will be able to find out the answer.
Someone could tell you YES, it’s worth the extra cost, but that is just thier opinion and you might find you dis-like Revell…
About the only thing I could think of to suggest for ya…hope it helps some.
it depends what your looking for. example: a revell car kit is cheap, easily built, and usually look great when done. a tamiya kit is expensive, takes a great deal of different paints and skills to do some of the newer kits but they look unbelievable when done. i have heard good of revell truckes though, try one.
Thanks for the good advise, which I shall follow. Which one do I choose though, in order to compare? Decisions, decisions. LOL
hey dude, i dont know if im right here but arent revell and itarei kits the same but just re-packaged? im thinking that coz of somethings that ive read im magazines… hope that someome can tell me if im right or wrong here…
Revell and Italeri kits aren’t the same. Well they might have copied one another…but they’re not the same. They are both two seperate entities, owned by 2 different parent companies.
If I dare give two words of advice:
_ Italeri is well known for reboxing a lot of old kits ( ESCI for instance)
_Revell has recently reboxed a significant number of Hasegawa kits of aircrafts. There was a joint venture on Arado 234 between them ( one made the twin jet version and the other one the four jet version) and even some Revell kits are sold in Japan under Hasegawa brand
So to say that as HistoryinScale said : compare by yourself with equivalent boxes aside and the answer could be obvious.
Sorry for the aircraft references but I’m an aircraft addict and I only came here to visit.
yes, some are, but im not sure abound trucks… one thing to watch out for is old reboxed trumpeter kits [xx(]
no, something to watch for is old hasegawa boxes. you may get a hasegawa, but you might get a monogram!! also for sure the 1/72 revell ta 152 H. it’s the old frog. avoid avoid avoid. best to do research.
