Like I stated on the topic of the discussion, I don’t really know if I should get some official panel liner (in the present case, for the cockpit and exteriors of a plane) or if I can get the same result with professional oil paints with the usual 10-90% mix ratio with white spirit. Then there’s the other option, that I guess would be using panel liner followed by a wash with the oil paints. In any case, it’s not clear to me if the panel liner must be treated with the same care as a wash.
Most than anything else, my doubts are about if the two techniques, or products, are used to perform the same result, or if they chase different objectives that can complement one another.
For example: If I wanted to highlight the panel lines of the cockpit with panel liner → first I paint it, then seal it with glossy acrylic, then panel line it? Would be the same using oil wash, or you don’t recommend it?
Oils are a much more forgiving medium to work with. Their slow drying time, allows plenty of chance to add to or remove from the wash, tint, filter, etc. Pre mixed panel line washes are pretty much a “one trick pony”.
Totally. I ended up getting some Oil Titan Goya colours to try some mixes of my own, and a bottle of odorless white spirit. I chose burnt sienna, raw and burn umber, and also ochre for mixing.
That’s a relief. I wasn’t sure if both techniques were thought to be used for the same thing. Today I was on a big mall and I ended up getting some Oil Titan Goya colours to try some mixes of my own, and a bottle of odorless white spirit. I chose burnt sienna, raw and burnt umber, and also ochre for mixing.
With all these, I hope I can be on my merryway for the time being with my planes and armour!
Much luck to you Gerard. I think that you will find oils to be quite fun. Especially when you start mixing. Get the primary colors as well, Red, yellow, and blue, along with some black and white. Between those colors and what you already have, the possibilities for mixing anything you need is right there.
