WIP Sherman Firefly dio
Hi all,
here’s a couple a photo’s of the dio I’m currently working on. This is the old Dragon Firefly kit.
Even though it’s an older kit, the build has been great fun!! The dio is an imaginary scene rather than an historical one, set somewhere in France, 1944.
Still have to fix the tracks to the road wheels, add and paint the stowage and tools.
The house still needs weathering and rubble. The river/creek needs another layer of resin water (ran out of resin during the first attempt). It’s my first attempt at grass (Woodland Scenics Static grass).
I’m after feedback, comments and suggestions as this is the first real dio I’ve done, well nearly finished [:D].
thanks in advance,
Jurgen.
Jurgen;
So far so good.
A couple comments.
Check the right track in the pictures it looks as though it has broken.
Vary the height of the various surfaces i.e. add a little height to the edges of the roadway to seperate the various features. Add some vegetation to the riverbank, some stones, boulders, or a reinforcing section over the culvert…
Cheers;
Gregory
Thanks Gregory.
yes, the tracks are still in sections, awaiting final fixing, hence the broken look.
I thought the river bank looked a little bare, but not sure whether tall grass/reeds would look correct or moss.
Thanks for the suggestion re the height. Now that you mention it, it really stands out.
Much appreciated.
Jurgen.
Don’t you hate it when people don’t read your post, and just throw comments out there…
Looks really good, the scene is very believable and has a nice picture story. The only thing I might coment on, and it’s not really a comment, more like a question. The building color, is the normal for that area?
Nice work…
Thank IYAAYAS.
I actually picked this building color based on the box art of another kit I have (diorama building of a farmhouse in France). As to whether it is normal for that area, I honestly don’t know.
I just liked the idea of some added color to the dio, but am happy to be corrected.
Hopefully someone can guide me either way as to whether the color is accurate or not.
Jurgen.
Very nice looking groundwork, and the Firefly looks great too. The building color might change with weathering, but the color looks fine to me. Are you planning to put in any figures for the diorama? I think a tank crew or some british troops might add a lot to the diorama.
thanks mg42gunner.
I’m actually stuck on how to weather the building anymore. The building at he moment has the base color, a light misting of Tamiya Buff, and a black wash.
As for figures, I am planning on using the Tamiya British Tank crew with the farmer.
The farmer will be talking to the tankers while salvaging materials from the ruined building.
Well, that’s the plan anyway.
Nice work, way better than my models and dioramas, how did you do the ground work? and is that stirofoam for the elevation and base?
Looking good so far, its a good thing your putting weathering on that building, it looks too diffrent. I sugest adding a figure in the command post on top of the tank turret, looks like you let the hach open so you better put a figure in.
Finally also put battle damage for the tank, looks better if you do.
Thanks T-rex.
The ground work is styrofoam layers cut to shape. That was covered with a mixture of fine sand, white glue (PVA glue here in OZ) and a little water. You can also add small stones, fine gravel and plant roots to the mix. I just spread it all over the surface. I left this to dry overnight. The next morning, I put white glue on the areas where I wanted the grass and sprinkled the areas with liberal amounts of static grass (Woodland Scenics).
*Tip: before adding the grass, place it in a plastic bottle or plastic cup and shake vigorously.
This ensure that the grass is very ‘static’ and will stand up when it hits the surface.
This was airbrushed Olive green, followed by a drybrushing of yellow and light green. The other ground work was airbrushed different shades of brown followed by buff. Then just gave it a dark wash.
I think I’m going to change the color of the building as I too am starting to think it looks too different (and am sick of my wife calling it the ‘Fanta’ building). I might go for an off white color.
I’m planing to put a figure in the turret talking to another tanker standing on the turrent. Will post some test shots.
Jurgen.
Thanks Jurgen
I was thinking of making a crash spitfire on a mud beach from a image I go from a war article, but whats hard is making the sandy beach with ground work and I didn’t know how but you help me. Thanks
One last thing, how did you made the building? Is it from another model kit or did you made it your self, and if you did how did you made it?
Thanks T-rex.
Sounds like a great dio you’re planning there. Really looking forward to seeing that!!!
The building is made from scratch. I drew the basic shape of each wall so I could get and idea of what I wanted. I used some old cardboard shop signs ( ‘Sale on now’ signs which are shinney on one side) and transfered the drawings to them and cut the basic shape out. I find that when you pour plaster onto the shinney side, it’s easier to remove the mould later. I cut strips of the same cardboard (approx 2 cm high) and tape the around the edges. What you have then is a basic mould. Just fill that with plaster and let it set. I you want bomb/bulding damage, you can scrunch up some foil and place it into the plaster while it’s still wet. When the plaster has set, just remove the foil and you have instant damage on the building. I can PM you with some photos of the process if you like.
Alternatively, you can just cut or scribe the damage. I then lightly sanded the walls and glued (with White Glue) the walls together and add Balsa Wood to create the building wood work.
Hope this makes sense.
Jurgen.
Great dio Marevic1. It is nice to see something that is not ‘flat’. Your use of the culvert is a great idea. That Sherman is just fantastic, personally i think your weathering is just right. Can’t wait to see it finished.
Are you going to put anything on the road that leads away from the side of the tank? That much road seems to be a little off balance from the rest of the diorama. Maybe a small obstacle/baricade or small vehicle like a jeep or motorcycle, hey, maybe a MP motorcycle and rider would do the trick? Imagination’s the limit…lol…where do you stop?
I was going to ask you about how you made the building but T-rex beat me to it! Your method is brilliant. It sounds so easy. I am defintely going to try that as soon as i finish my dioramas i have on the bench. Thanks for aswering T-rex’s question so simply.
Can i ask about your method of getting photos on here. I am bashing [banghead] trying to work it out! I have read other posts on how to do it and have tried using photobucket as suggested but have had no luck yet[tdn].
Keep up the good work! Where in oz do you live?
Thanks Boomerang.
Would love to add a burnt out wreck as a road obstruction, but doubt that I’ll be able to get it done. Hoping to have the dio finished by next weekend for a local show. Maybe I’ll add that after.
As for the way I load the photos, I use http://photos.kitmaker.net/.
Just register and upload you pics. You can then reference them in you posts.
If you need a hand, just PM me.
I’m from Melbourne. I noticed you’re from Newcastle. Any good model stores up there?
thanks for the encouragment.
Jurgen.
Hey Jurgen, you are a legend mate![bow]. Itried your suggestion and uploaded a pic through Kitmaker. It worked like a charm.[tup][tup]. Now my next challenge is to take good quality pics so that i can post them and get this forum thing really happening.
Newcastle has Frontline Hobbies. It would have to be the biggest hobby shop in the country. I have to go there at least every couple of weekends to get my ‘frontline fix’. I don’t always buy anything, i just have to be there…you know what i mean?
Melboure is not bad, Victoria is a beautiful state. I always head down to the Avalon Airshow, which is in a couple of weekends…i had better get organised! Can’t wait.
I meant to comment on the colour of your building. Maybe it is a little too bright but in some of your pics it doesn’t look too bad. I find that what can look ok in real life can look a little strange when it is in scale. It is a challenge to achieve a ‘scale colour’. That’s where my quote ‘if it looks wrong , then it probably is’ comes from. Sometimes you have to experiment with the colour until it looks right. Another thing that i often find is that, especially modelling WW2 subjects is that most pictures we look at or motion footage is always in black and white. Therefore i always seem to think of that era in black and white. It makes it very hard to when making dioramas to come up with the right colours. What i am trying to say is that maybe your building is not too bad. How do we tell?
Does anybody on this forum have opinions on ‘scale colour’? Should you lighten or darken some colours to get the right effect?
Hope to chat to again soon. Thanks again for your help with posting pics.
Ya I would like those photos of how to make the building please.
Also I’d just bought a Czech building for another diorama, but the wall of the building doesn’t seem like pieces to cut out, are they mold of parts. I’ll the images of a pieces soon, Thanks.
Hi all.
Another update, this time just the dio base. Have added some garden dirt, small stones and twigs and roots. It looked too clean before. A couple of stone and a ‘tree’ added to the river. Have added some more resin for the water. I have repainted the house and painted the brickwork.
Still have some weathering and cleanup work to do as well as add some more grass, but it’s nearing completion.
Any comments or suggestions greatly appreciated.
thanks,
Jurgen.
The house looks much better in white, very realistic weathering on it, and the water looks great. The dirt on the ground also makes the diorama look less ‘flat’. Fantastic, its really coming together nicely.
What a difference! That looks just great. Hey, weren’t you supposed to have it finished for this weekend? …lol.
WOW! Looks great! Nice work!
I must admit. My eyes went directly to the drainish pipe. That is a great dio. [tup][tup][tup]
