I would love to model my Stuka in winter camo from it’s campaigns in Finland or Scandanavia.
Anyone have any great examples I could check out?
Mark
Mark
Google is your friend…type in Ju87…click then click images at the top of the page…
Essentially they used the Huckleberry Finn method…white wash the upper surfaces to break up the dark camo.
This is a Stuka 87D I did a while back. I found this unusual winter scheme off the decal set I used for it. The service was in Russia 1943-44. Instead of a white wash, white dots were sprayed over the original splinter camo. Also, check out the Wing’s Palette site. They have an extensive marking/color archive.
Andy
Be careful - I’d want photographic evidence that Stukas were actually used in combat in those areas during the winter months, as opposed to spring or summer. Norway especially.
Cheers,
Chris.
I did a winter camo on an Fw-190A-6 in the Feb 2008 issue of Scale Aircraft Modeller abd tried to explain the basics for application of the finish. They are quite variable but it would give you a starting point to work from. But I second Chris and confirm winter camo from photographic evidence or at the very least a profile in a book.
Here’s a couple.
Jerry
Looks like it could be the same aircraft in the photo as the profile. Shows how innacurate the profiles can be sometimes.
