WINDOW LIKE CRYSTAL
I SAWA TUTORIAL ON SANDING THEN DIPPING A WINDOW IN FUTURE FLOOR WAX DOES THIS WORK ANY IDEAS ON VARIATIONS OR RESULTS FROM SOME OF YOU FELLAS WORK WITH THIS ALSO I USED CARNUBA CAR WAX IT SHINES AND REVITALIZES PAINT IT WORKED PRETTY GOOD ANY ONE ELSE EVER USED IT HOW DID IT WORK FOR YOU
Deano,
Pretty much anything anyone says about the uses and benefits of Future are probably true. It covers scratches very well in clear parts and does a great job on paintwork. Get some and you’ll not regret it.
Just remember it doesn’t like to go on with a heavy coat all at once - several dust coats are needed before a final wet coat - patience is a virtue!!
Cheers, Lee Tree
I just would like to add that airbrushing Future onto a waxed model is not a good idea! I use Turtle Wax after my numerous coats of Future.
