window frames
how do you pros out there use the foil trick on the windows and windshield what is it and how do you apply it i have been doing very touchy chrome silver paint and a small brush[V]
Deano, get off to your local hobby shop and get yourself some Bare Metal Foil. If they don’t have any, go to their website
( http://www.bare-metal.com ) and get some.
Using their foil is as simple as it sounds. For a chrome windscreen surround, simply cut 4 thin lengths of the self adhesive foil, carefully place it, burnish it down with something like a Q-tip, then using a new no. 11 X-acto blade, trim the excess off. It really is that simple.[:D]
The stuff is great for masking areas that you don’t want to paint - especially good on planes.
The foil is absolutely perfect for chrome trim on the sides of cars, covering those nasty sprue attachment points on chrome parts, and about a hundred other uses.
Try some - It’s really good stuff. Good luck!!
He’s right, it is so easy to use, and looks extremely realistic. A sheet will run you about $5. Lee says get it man, you’ll never go back to silver paint!
Lee
LOL THANKS GUYS ILL DEFINATELY GET SOME IM GONNA LOOK AT HOBBY LOBBY IF NOT THERE ILL GO ONLINE
