White paint gone yellow?
As I mentioned in the aircraft section, I am working on cleaning up loose ends on completed kits, and my first task is an FB-111A that never received its drop tanks. As I paint up the white undersides of the tanks, (SAC bomber scheme) I notice the belly of the plane has a yellowish tinge to it although it was painted with MM white over 15 years ago! I really don’t plan to try to correct any of this, but just wondered as to what my have caused this?
  1. The paint itself?
  2. The Testors lacquer-based Glosscoat/Dullcoat combo used to finish it, or…
  3. I lived then with several smokers (Yuck!) back then, (I gave that up many years ago!) and notice every thing ends up with that brownish stain-
  4. Combinations of the above?
Just your thoughts on this…
I have had Testors white go yellow in the past (more than twenty years ago). I have not had this problem with the paints I have used in the past couple of decades, but I know of several folks who have noticed this effect with the older paints. I don’t think you will have problems with the paints you get off the hobby shop shelves today.
I’ve had probs years ago with old humbrol white going ‘off’ & ditto humbrol varnish.
Some painters suggest putting the smallest trace of blue in the paint, to ‘blue’ it un-noticeably, this stops the yellowing.
For Varnish, I’ve been using Future, with no noticeable effects, except when I’ve wanted the canopy gold, green, or blue tinted.
But have been working with Vallejo paints for the last few years & haven’t used the white in any quantity, so can’t comment about how well Vallejo white holds up.
I am a lifelong modeller & professional coatings chemist. Paint can turn yellow for various reasons. Chief among these is the selection of base resin used by the paint manufacturer. Older alkyd resins can turn yellow after some time and even some new paint can yellow due to antioxidants not being added to the paint when it is being manufactured. The pigment used to make white paint is called Titanium Dioxide. Low grade Titanium Dioxide (anatase type) can darken over time and give the paint film a yellow tint.
Maybe there was a touch of non-slip gelb in it?
A trick worth trying is to “bleach” the white with a light source strong in ultraviolet. Try placing the model belly-up in a window or under a fluorescent lamp for 2 - 3 days and see if the white loses its yellowish tinge.
