Any recommendations? I use Testors enamel primer that is very expensive and runs out quickly. I’m sure I can get an automotive primer that will just as well and it will give me a big can for smaller price!
Wal Mart. White, Grey, black. $2.00 each big can. Tamiya white primer is better but more expensive.
Whatever primer you get in an auto parts store.
I say that because it is getting to be a bit harder to find good metal primers. Seems to be that stores that have paints seem to be specializing more. I find many hardware stores are selling paints that need no primer for wood or plastic. Seems like the general public must not be painting metal items as much any more. Most paints and primers that I find in auto parts stores are intended to paint metal. But I see fewer and fewer of the old auto paint brands.
I’ll second WalMart’s house brand, whatever it may be called at the moment-the label has changed a couple of times, but it seems to be the same paint.
I still use Tamiya’s fine surface primer, because it is is just that-a fine surface primer. It produces a finely-granulated surface for paint to adhere to. The automotive primer is a tad rougher, as applied. Of course, it can be buffed or sanded, too. But I have occasion to use one over the other, so I have both in my paint cabinet.
I have been very happy with duplicolor sandable primer. It sprays on nice and flat and even though it’s a filling primer, I find it holds even the finest surface details and dries super fast. It comes in white, hot rod grey, black and red oxide in 12oz cans and I pay around $7 and it lasts a really long time with light coats. I have used white and black on my last 4 builds with both acrylic and laquer top coats.
Older thread, I know. But I’m in a similar situation and wanted to see if there are any updates. I’m painting a car model, and want to use automotive single-stage enamel for the topcoat. It would seem prudent to use a primer, since the enamel might be too aggressive on the bare plastic. I tried a rattle-can automotive primer, and even with care, it built up too much and obscured details. I’ve stripped it off to start over. I’m looking for something I can use either straight out of the can or in my airbrush to get a fine coat that doesn’t require much (preferably any) sanding.
I only use Tamiya. Never had any issues with it.
@MonsterZero, Plasti-Kote and Dupli-Color are great general purpose primers straight out of the can or sprayed into a cup for your AB.
@the_tool_man, As mentioned by, @the_Baron and @Marc_Ross, Tamiya Fine is indeed fine. I use for figures to avoid successive sanding the grainy textures away.
