I am building a tamiya flak gun 1:48 scale and i seem to have lost the poly caps from the kit. hence i used the ones from my tamiya 1:48 corsair. now i have the problem that i wont have any for the corsair, the corsair had 2 in the kit but it looks like it only needed one, are thre any other tamiya kits which have spare poly caps in them?
You might want to try and hit the kit review sights. They can tell you exactly what is included with any Tamiya kit. Most of the Tamiya kits include more than are required to build the kit for some reason. If you were here in the States I would drop one in the mail to you as I must have at least twenty of them rolling around in the spares box from all of my model building activity over the last 30 years. Mabye someone down under can help you out if they have some in thier spares box. There are quite a few of your fellow countrymen that post frequently here.
[#ditto] Same here Postal. Every kit I have has come with multipule poly-caps. I can probably build an airplane out of all the ones I have on hand. ( It would look pretty weird but, you get the point)[:D] Lemme know what you need and I can send them to you.
On a side note, the poly-caps are only neccesary if you want the prop to spin. If you don’t care one way or another, then don’t sweat it, just glue the prop in place.
