What's your least favorite step?
Hey i was just curious. What is everyone least favorite step in modeling from start to finish? The task that seems to take me the most time, and my least favorite has got to be seam filling. So whats yours?
Mine would probably be decals. Cos if you stuff up any other step it can be fixed, decals, if you stuff them up, takes a bit more time and effort to fix, also decals make or break a model alot of the time. Also i never know when to say “right, kits done, decal time”
Paying for them [:P]
Sanding seams and restoring raised panel lines since I build Revell/Monogram kits exclusively
Masking canopies.
I hate smoothing seams.
[dto:]
My least favorite step is when the painting commences. Having to wait between color and coats, not to mention having to clean the airbrush at each use.
Sanding seams and filling them.
Probably masking complex canopies.
Decals
Will they stay together or shatter
Will they go well or silver
landing gear & weapons.
Another vote on canopies. The new pre-cut masks make them a lot easier but they still really irritate me.
One of the things I really like about armour is not much in the way of transparent parts there.
tie between masking and decals.
[dto:]
its a tie between seams and masking canopies for me
**redraider:-**have a look at these for replacing raised detail
http://www.archertransfers.com/catSurfaceDetails.html
Not being able to build OOB (out of box) Its the moment when I start adding a few scratch built details and realize a ‘quick build’ has turned into a quagmire of scratch built details of my own making.
The second worst moment is realizing most will not be seen or appreciated on the finished model![:O]
The best moment is finishing a model to my satisfaction knowing it would be impossible to recreate it in the exact same way. [H]
Amen brother!!! Words to live by I think!!![t$t]
tie between filling the seams and masking the canopies.
Seam-filling & sanding… All my models are for dioramas and get permanently attached to the base, so I skip a LOT of seam-work on the undersides…
