What to Thin Krylon COLORmaxx Acrylic Crystal Clear with?
Hi,
If I decant Krylon COLORmaxx Acrylic Crystal Clear to use in my airbrush, what do I use as a thinner? Even if it does not need a thinner, still need what I should use to clean my airbrush after using.
Thank you in advance for any help.
Joel
From what I gather from the SDS, it’s got some pretty hot chemicals. Most of them are similar to lacquer ingredients. So I’d say use lacquer thinner for thinning and clean up. I also suggest you test it before you apply to a precious model!
Thank you!
