What do the term "washing" in modelling really mean?
I am confused about the technique called “washing” does it mean diluting the paint very thinly and soak the entire part in that paint and let it dry naturally?
I’ve heard “washing” most commonly on tanks and armour. One specific question is that, to create the rusty tracks of the tanks, one dilute the colour rust and soak the tracks in it?
please enlighten me.
My method of ‘washing’ is to add black (or dark brown) to the base colour of paint. Then, as you say, dilute it very heavily so it’s almost more of a tinted thinner.
I’ll run the wash over the entire model taking note of where the dark patches seem to be settling. Ideally, what you want is for the wash to settle in all the little nooks and crannies, and not so much the wide flat areas of the model. You can easily remove the wash from an area with a cloth or (lint free) tissue.
Quite often, you’ll find yourself repeating the wash in certain areas until the desired effect is just right. When the wash is dry, you create a contrast by drybrushing the model with a lighter shade of the base colour. Smaller details will really stand out nicely when drybrushed.
As for the tracks, I always mix up a dark brown or dark rust colour and paint the tracks with that. After that’s dry, I drybrush silver onto the parts that contact the ground, and drybrush a lighter rust colour onto other parts that would not be in constant contact with the ground while the vehicle is moving. I generally find it’s not necessary to ‘wash’ the tracks as the base colour I use is usually dark enough.
There are lots of ways of acheiving good results. I’m sure other people will have somewhat different methods than mine. You just have to find what method works best for you.
Rich gave some good answers to what a wash is. I agree and will add that you don’t have to use paint. India ink with water or alcohol is common. India ink comes in many colors other than black. Don’t make your washes too strong. It’s better to have a very light wash and repeat until you get the effect you want than to have a heavy dark wash and not be able to reverse it. My favorite wash is with artist oils and oil paint thinner. Anything from light gray to burnt umber.
